how connect feature table?
6476
7
09-29-2015 11:40 AM
NickKula
I need connect featuretable and layer to programm on QML,
    Geodatabase{
        path: "C:/Qt/prjcts/2nd.geodatabase"
    Map{
        ArcGISLocalTiledLayer{
            path: "C:/Qt/prjcts/2nd.tpk"
  GeodatabaseFeatureTable{
            geodatabase: gdb
            featureServiceLayerName: "a2"
        FeatureLayer {
            featureTable: gdbtable
            selectionColor: "cyan"
LucasDanzinger
Esri Frequent Contributor
Hi Nick,
If you use just the code I sent without the tpk, it works. Once you add the TPK, it doesn't work. This is because your TPK is in spatial ref 102100, while your gdb is in 2610. We don't support on the fly auto reprojection with the offline gdb, so when you are clicking on what looks like your feature layer, you are actually just clicking on the TPK, and the gdb isn't actually displaying on your screen.
Since the map's spatial reference is defined by the first layer added to it, you have a couple options:
1) Create your TPK in 2610 instead of 102100 (web mercator). This would require you to create the necessary tiling scheme in ArcMap as opposed to using the AGOL/Bing/Google tiling scheme, which makes it 102100. Once you have your TPK in the correct spatial reference, the geodatabase that is in that spatial reference will display as expected
2) Continue using the TPK that is in 102100, and re-create your geodatabase in 102100 instead of 2610. If you are creating the geodatabase from an online feature service, you can pass the desired spatial reference into the sync parameters. If you are creating it from ArcMap, you can change the data frame's spatial reference to 102100.
Hope this helps.
-Luke
NickKula
(*accidentally sent)
..,  i do this like this code. But programm don't finds featuretable, at least consider it empty..
How correctly connect feature table and layer to program?
LucasDanzinger
Nick-
Your code looks good. Does the feature service layer name match "a2"? You can also try doing feature service layer index and specify the index instead of the name. If that doesn't work, can you attach a sample geodatabase?
Luke
NickKula
I have set up a connection geodatabase. But now there was a problem that the program does not find any object on the map from connected featuretable.
The program sees that in my featuretable has 26 objects. But ".findFeatures" - does not find features.
here database:
LucasDanzinger
Nick-
Give something like this a try:
import QtQuick 2.3
import QtQuick.Controls 1.2
import ArcGIS.Runtime 10.26
ApplicationWindow {
    width: 800
    height: 600
    Geodatabase {
        path: "/Users/username/Desktop/second.geodatabase"
        geodatabase: gdb
        featureServiceLayerId: 0
    Map {
        anchors.fill: parent
        focus: true
        FeatureLayer {
        onMouseClicked: {
            var featureList = featureLayer.findFeatures(mouse.x,mouse.y,2,20)
            console.log("number of features:", featureList.length);
            for (var i = 0; i < featureList.length; i++) {
                console.log("feature id is:", featureList);
NickKula
In console: "qml: number of features: 0"
Maybe I did the wrong database or tpk file..
My files:
LucasDanzinger
Hi Nick,
Hope this helps.
-Luke
ADAada
I am try to use this code for feature layer  and its work
but I want to identify the fields from file geodatabase , but the attrbut qml is null
can help me ?
