Generate Offline Map Sample giving "Mobile map directory path is not specified" error.
1305
04-01-2019 08:46 AM
PamTurner
Hi All - I'm trying to use the "Generate Offline Map" sample and am running into an error that is telling me that the mobile map directory path is not specified.
qml: error: Invalid argument Mobile map directory path is not specified.
I have tried hard coding the path in the sample to "c:\temp\out.mmpk" just in case my URL variable was not working correctly, but it still is giving me the same result. The only thing I have changed is to give it my own portal item which is a webmap that is available to the public for testing purposes.
I'm sure I'm missing something very simple as I'm new to Qt/QML. Any insights would be appreciated. Code is below, but it's almost identical to the original sample.
Thanks in advance!
        // Create a button and anchor it to the attribution top
        QtControls.Button {
            anchors {
                horizontalCenter: parent.horizontalCenter
                bottom: parent.verticalCenter
                margins: 5 * scaleFactor
            visible: map.loadStatus === Enums.LoadStatusLoaded
            onClicked: extentRectangle.getRectangleEnvelope();
    // Create an extent rectangle for selecting the offline area
    Rectangle {
        anchors.centerIn: parent
        width: parent.width - (50 * scaleFactor)
        height: parent.height - (125 * scaleFactor)
        color: "transparent"
        border {
            color: "red"
            width: 3 * scaleFactor
        function getRectangleEnvelope() {
            var corner1 = mapView.screenToLocation(extentRectangle.x, extentRectangle.y);
            var corner2 = mapView.screenToLocation((extentRectangle.x + extentRectangle.width), (extentRectangle.y + extentRectangle.height));
            var envBuilder = ArcGISRuntimeEnvironment.createObject("EnvelopeBuilder");
            envBuilder.setCorners(corner1, corner2);
            var mapExtent = GeometryEngine.project(envBuilder.geometry, SpatialReference.createWebMercator());
            offlineMapTask.createDefaultGenerateOfflineMapParameters(mapExtent);
    // Create Offline Map Task
    OfflineMapTask {
        portalItem: mapPortalItem
        //onlineMap: map
        property var generateJob
        onErrorChanged: console.log("error:", error.message, error.additionalMessage);
         onCreateDefaultGenerateOfflineMapParametersStatusChanged: {
            if (createDefaultGenerateOfflineMapParametersStatus !== Enums.TaskStatusCompleted)
                return;
            // Take the map offline once the parameters are generated
            takeMapOffline(offlineMapTask.createDefaultGenerateOfflineMapParametersResult);
        function takeMapOffline(parameters) {
            // create the job
            generateJob = offlineMapTask.generateOfflineMap(parameters, "c:\temp\out.mmpk");
            console.log(mapPortalItem.url);
            console.log(mapPortalItem.itemId);
            console.log(mapPortalItem.type);
            // check if job is valid
            if (generateJob) {
                // show the export window
                generateWindow.visible = true;
                console.log("Path: " + generateJob.downloadDirectoryPath);
                console.log("test: "+ generateJob.parameters.areaOfInterest);
                // connect to the job's status changed signal to know once it is done
                generateJob.jobStatusChanged.connect(updateJobStatus);
                // connect to the job's progress changed signal
                generateJob.progressChanged.connect(updateProgress);
                generateJob.start();
            } else {
                generateWindow.statusText = "Task failed";
                generateWindow.hideWindow(5000);
                 console.log("error:", generateJob.error.message, generateJob.error.additionalMessage);
        function updateJobStatus() {
            switch(generateJob.jobStatus) {
            case Enums.JobStatusFailed:
                break;
            case Enums.JobStatusNotStarted:
                generateWindow.statusText = "Job not started";
                break;
            case Enums.JobStatusPaused:
                generateWindow.statusText = "Job paused";
                break;
            case Enums.JobStatusStarted:
                generateWindow.statusText = "In progress";
                break;
            case Enums.JobStatusSucceeded:
                // show any layer errors
                if (generateJob.result.hasErrors) {
                    var layerErrors = generateJob.result.layerErrors;
                    var errorText = "";
                    for (var i = 0; i < layerErrors.length; i++) {
                        var errorPair = layerErrors[i];
                        errorText += errorPair.layer.name + ": " + errorPair.error.message + "\n";
                    msgDialog.detailedText = errorText;
                    msgDialog.open();
                // show the map
                generateWindow.statusText = "Complete";
                generateWindow.hideWindow(1500);
                displayOfflineMap(generateJob.result);
                break;
            default:
                console.log("default");
                break;
        function updateProgress() {
            generateWindow.progressText = generateJob.progress;
        function displayOfflineMap(result) {
            // Set the offline map to the MapView
            mapView.map = result.offlineMap;
            downloadButton.visible = false;
            extentRectangle.visible = false;
        Component.onDestruction: {
            if (generateJob) {
                generateJob.jobStatusChanged.disconnect(updateJobStatus);
                generateJob.progressChanged.disconnect(updateProgress);
    GenerateWindow {
        anchors.fill: parent
    MessageDialog {
        title: "Layer Errors"
        text: "Some layers could not be taken offline."
by Anonymous User
Not applicable
Hi Pam,
I suspect the issue may be the string "c:\temp\out.mmpk".
The backslash has a special meaning in Javascript. (And by extension, QML!) In this case if I print the above path to console I get:
c: empout.mmpk
To escape the special meaning, you would either need to write the path as:
"c:\\temp\\out.mmpk" or as "c:/temp/out.mmpk".
I would recommend using forward slashes if you can. Qt accepts forward slashes for paths on every platform!
Also as a final note - generateOfflineMap accepts a QUrl as an argument. This sometimes means you need to be explicit with the protocol you are using, such as fully qualifying your path to: "file:///C:/temp/out.mmpk"
I have seen in the past QML convert an unqualified URL to "qrc://C:/temp/out.mmpk", which is not what you want!
Hope this helps.
