FeatureRenderingModeStatic in shapefile loaded locally with a strange shadow
1302
05-03-2022 08:22 PM
HomeroOriaAguilera
Hi...again.
I have this large shapefile dataset (200k points approx.) and I want to load it from a file (locally) with renderingMode in FeatureRenderingModeStatic.
The problem is that it appears this strange shadow above the Basemap and the FeatureLayer.
I think this isn't normal, right? Any thoughts?
JamesBallard1
@HomeroOriaAguilera no that doesn't look right. I assume it's the same or similar dataset from https://community.esri.com/t5/arcgis-runtime-sdk-for-qt-questions/large-shapefile-dataset-load-proce...
Are you able to share the dataset so we can take a look into the static rendering problem? You can send it to me directly if you don't want to post it on the forum. If it's sensitive data we can try to come up with something on our end to reproduce the problem.
HomeroOriaAguilera
Hi @JamesBallard1, yes it's kind of sensitive data. But I have the authorization to share with you in order to solve this issue. Do you have some private channel to send a link to the dataset?
JamesBallard1
@HomeroOriaAguilera yes, we have something that will work. I will reach out to you directly with the details.
