Does SceneGraphicsView Emits scale changed signal?
1131
12-11-2019 03:28 AM
GirishchandraY
Hello Team,
I have previously used map scale changed on MapGraphicsView which is working fine.
But if I want to do same on SceneGraphicsView option is not there.
Can you please check.
LucasDanzinger
Esri Frequent Contributor
Did you try setting mouseTracking on the view? The following works for me:
m_sceneView = new SceneGraphicsView(scene, this);
m_sceneView->setMouseTracking(true);
connect(m_sceneView, &SceneGraphicsView::mouseMoved, this, [this](QMouseEvent e)
  qDebug() << e.x() << e.y();
GirishchandraY
Thank you for mouseMoved option.
Actually I had changed question later to
LucasDanzinger
In SceneView, you will need to connect to viewpointChanged - SceneGraphicsView Class | ArcGIS for Developers
And then when that emits, access SceneView::currentViewpointCamera - SceneView Class | ArcGIS for Developers
