Cannot Move createObject
1800
01-12-2021 11:16 PM
Tkm_Knj
Hi, I want to use createObject for change Basemap, but I got error.
That error is:
[ TypeError: Property 'createObject' of object [object Object] is not a function ]
I try to copy for sample code, but got a same error.
Why get this error?
I use ArcGIS ver100.8 , Qt 1.15.0 ,and  MSVC2019.
How do I deal with this?
LucasDanzinger
Esri Frequent Contributor
This is due to a change in Qt starting at 5.15. The solution is to either stick with Qt 5.15 and upgrade to Runtime 100.9, or if you need to stick with Runtime 100.8, downgrade Qt versions to 5.12/13/14.
Details on this change are highlighted in this blog - https://community.esri.com/t5/arcgis-runtime-sdks-blog/qml-api-breaking-changes-with-5-15/ba-p/88865...
LucasDanzinger
Tkm_Knj
Oh, I see...
I  downgraded Qt version to 5.14.
Thanks.
