Any solutions to display the ArcGis map after reconnecting to the net using Qt
992
01-18-2021 01:26 AM
MoritaTsuguhiro
Dear Sir or Madam
Could you tell me any ways to display  the ArcGis map after reconnecting to the net using Qt?
I  try to open the ArcGis map using Qt/QML online like
//Qml File(Esri.ArcGISRuntime 100.8 Qt 5.15.2 Windows10)
import xxxxxxxxxxxxx
property xxxxxxxxxxxxxxxx
Map {
    BasemapTopographic {}
If  the app firstly connect to the net,  it can display the map because I use a online map.
On the other hand , if I open the app in case of offline firstly, it cannot display the map . And Even if my pc can connect to the net, the app cannot display the map.
I don't know how to display the ArcGis map after reconnecting to the net.
Best regards
by Anonymous User
Not applicable
Hi Morita,
Async tasks like this normally follow our loadable pattern. If a failure to load has occured (i.e. no network connection), you call `retryLoad()` on the map to try again.
by Anonymous User
Not applicable
Hi Morita,
MoritaTsuguhiro
Hello NeilMacDonald
Thank you  for replying.
I could load my map again !
