calculate distance between 2 coordinates returned by PositionSource
1258
08-26-2020 03:02 AM
rsharma
Hi i want to calculate distance betweeen 2 coordinates returned one after other to calculate distance between them.
I found distanceTo() function , but didn't get any example. how to use it
LucasDanzinger
Esri Frequent Contributor
There is the GeometryEngine distance method and the distanceGeodetic method. Distance will give you simple planar distance and distanceGeodetic will give you a more accurate distance - GeometryEngine QML Type | ArcGIS for Developers
Here is an example arcgis-runtime-samples-qt/ArcGISRuntimeSDKQt_QMLSamples/Geometry/GeodesicOperations at master · Esri...
LucasDanzinger
