ArcGISRuntimeEnvironment.h file not found
1850
6
05-31-2022 03:20 AM
VincentB38
Hello,
I try to compile my application on QT with MSVC_2019. I install the sdk with the guide but, whene i try to compile, i have this error. I re-install two times (MSVC and SDK) but, it's the same problem, i can't compile my projet. I try to use the example propose by Argis, it's work, but, whene i would like add the library ArcGISRuntimeEnvironment.h  the compilation crash...
Can you help me please ?
VincentB38
hello @Anonymous User
I fixe the bug, i used QML application example but, i need to use Widget application for use this configuration. I change my configuration and the probeme was fixed !
Thank's for your help !
Bnoble
Hello VincentB38,
Can you share with us the error(s) you are receiving? Thanks.
VincentB38
my error message (copy and past)  : C:\Users\<user name>\Documents\code\<file>\<project name>\src\gui\<file with ArcGISRuntimeEnvironment.h> :2: erreur : C1083: Impossible d'ouvrir le fichier includeÿ: 'ArcGISRuntimeEnvironment.h'ÿ: No such file or directory
by Anonymous User
Not applicable
Can you look in your installation path for the ArcGISRuntimeEnvironment.h?
For me, it is located at C:\Program Fils (x86)\ArcGIS SDKs\Qt100.14\sdk\include\
Let me know if you find it there.
VincentB38
I looked my folder and i have this file :
by Anonymous User
Not applicable
Are you able to build any of the template apps? It sounds like you are trying to build a c++ app. If thats the case, let me know if you are able to build and run one of the Qt Quick C++ app.
VincentB38
