ArcGIS RT sdk for Qt multithread ... not yet!
3782
12-02-2014 04:47 AM
RomeoCureliuc
I was wondering if the new ArcGIS RT for Qt is multithread supported ( move some working process in another thread different that the main thread)
Thanks
Romeo
LucasDanzinger
Esri Frequent Contributor
Romeo-
The API is multithreaded- what exactly are you trying to do?
For example, if you are running tasks, you don't need to try and run it in another thread- we do that for you. Are you trying to call moveToThread() on a runtime task (QObject) that is already created in the UI thread? If that is what you are doing, perhaps you could instantiate the taskin the other thread instead of the UI thread?
If this isn't the case, or you are needing further clarification, please let me know. Example code or further explanation of your workflow would be great.
Luke
