ArcGIS Runtime for Qt.  syntax error : missing ';' before '*' when compiling rtsample.h
3238
08-10-2014 04:12 AM
StevenBowley1
Has anyone encountered this problem with the Qt runtime sample code?
When including the rtsample.h file in my map project, Qt creator throws a syntax error in the rtsample.h file.
C:\Users\Steve\Documents\SDK\Projects\MyFirstMap\rtsample.h:73: error: C2143: syntax error : missing ';' before '*'
fails on Line 73: QTextEdit* getSourceFile(const QString& fileName);
It doesn't like the *, says there is a missing ;
private:
  void addSourceTab(const QString& fileName);
Looks fine to me, same as the sample code, but won't compile.
Using:
Qt-5.1.1-32,
qtcreator-3.1.2
arcgisruntime10.2.3
any help much appreciated!
Steve
LucasDanzinger
Esri Frequent Contributor
Hey Steve,
Sorry for the late reply. What exactly are you trying to do here? Are you trying to compile the Qt Sample App?
