ArcGis issues facing on loading shape file using qt
886
10-22-2019 11:52 PM
GOVARDHANREDDY
Hi ,
    i have used Qt 5.12.3 (GCC 5.3.1 20160406 (Red Hat 5.3.1-6), 64 bit)  version and installed ArcGIS Runtime SDK for Qt in it. It is running successfully and checked the basemap is showing up properly.i have used the sample code which is present to load the shape file  but facing issue when loading it. A member “datapath” is present to which we are giving shapefile (.shp file) but it is not loading.
In the same way i tried to use ArcGIS online to load the text file & zip file to load and it is successfully loaded but in Qt tried to implement the same and  it is not getting successful.
I have Attached a file for reference.
I need help in above issue and kindly do needful.
Regards and Thanks
Govardhan Reddy S
LucasDanzinger
Esri Frequent Contributor
I don't see a file attached. Can you retry please?
This sample code should be able to be modified to reference the path to your .shp - arcgis-runtime-samples-qt/ArcGISRuntimeSDKQt_CppSamples/Layers/FeatureLayerShapefile at master · Esr...
