Add Geodatabase layer to Map
1353
03-05-2019 01:38 PM
LaurynasGedminas2
How to add local Geodatabase feature class grammatically to the Map object created thru: ArcGISRuntimeEnvironment.createObject("Map",{});  ?
Thank you
LucasDanzinger
Esri Frequent Contributor
Here is some code to do this - arcgis-runtime-samples-qt/FeatureLayer_Geodatabase.qml at master · Esri/arcgis-runtime-samples-qt · ...
Essentially you need to:
- Create a Geodatabase object via the path to the local file - Geodatabase QML Type | ArcGIS for Developers
- Iterate through the list of GeodatabaseFeatureTable objects - Geodatabase QML Type | ArcGIS for Developers
- For each feature table, create a Feature Layer by setting the featureTable property - FeatureLayer QML Type | ArcGIS for Developers
- Add the FeatureLayers to the Map's operational layer list model
LaurynasGedminas2
I am trying to create the Map object from Geodatabase layer:
var geodb = ArcGISRuntimeEnvironment.createObject("Geodatabase", {path: outputGdb});
var t1 = geodb.geodatabaseFeatureTablesByTableName["offline_test"];
var fc = ArcGISRuntimeEnvironment.createObject("FeatureLayer", {featureTable: t1
var map2 = ArcGISRuntimeEnvironment.createObject("Map",{});
map2.operationalLayers.append(fc);
mapView.map = map2;
Map loads with no data, is this wrong way to load GB data programmatically?
Thank you,
LaurynasGedminas2
Proper way:
        path: outputGdb});
geodb.loadStatusChanged.connect(function () {
     if (Enums.LoadStatusLoaded === geodb.loadStatus) {
                        var tables = geodb.geodatabaseFeatureTables;
                           {featureTable: t1});
                        var map = ArcGISRuntimeEnvironment.createObject("Map",{});
                        map.operationalLayers.append(fc);
                        mapView.map = map;
Thank you,
