XYsetVALUE not supported in ArcGis Pro
3763
08-31-2018 07:27 AM
AdminValorInmueble
Hi, I was investigating on my own, but I did not get a solution.
I need to move points in a massive way to specific coordinates,
I found a phyton code that makes it perfect in ArcMap,
but the problem is that the points are a feature service,
and in ArcMap it is not so easy to edit, and the service is very heavy for a local copy,
then, I thought I would do it directly in ArcGis Pro, but I get the following error:
some idea of how to do this process in ArcGis Pro?
Thanks!
XanderBakker
Esri Esteemed Contributor
I just tried this and it worked:
The reason might be the fact that you are returning a point object when the geometry is a PointGeometry object.
Code Block:
def Move2NewLoc(pntg, x, y):
    pntg_new = arcpy.PointGeometry(arcpy.Point(x, y), pntg.spatialReference)
    return pntg_new
DanPatterson_Retired
did you validate the expression?
XanderBakker
Code Block:
    return pntg_new
AdminValorInmueble
It works perfect,
thank you so much, you have save my life !
XanderBakker
You're welcome. Glad it worked. Please mark the post as the correct answer for others to find this answer easier.
MiguelMartinezYordan
Hi, for some reason, this code used to work, but now is moving all points to the west African cost (see attachment). Any suggestion???
