Sequential Numbering Python Script for Field Calculator in Arc 10.2
2987
03-30-2017 05:21 AM
KennyDonaldson
Hi
I'm looking for a python script to populate an ID field in ACRGIS 10.2 with a sequential number that resets when the value of site field changes. e.g.
Site      ID
SIte A   0001
Site A   0002
SIte A   0003
Site A   0004
SIte A   0005
Site B   0001
SIte B   0002
Site B   0003
Site C   0001
SIte C   0002
I've been using Arc for a number of years but have no python skills yet.
Thanks
Kenny
DanPatterson_Retired
Try
old = ""
cnt = 0
def seq_count(val):
    global old
    global cnt
    if old == val:
        cnt += 1
        ret = "{} {:04.0f}".format(val, cnt)
    else:
        cnt = 0
    old = val
    return ret
__esri_field_calculator_splitter__
seq_count(!Test!)   # replace the field name with the data field
You can save this as sequential_count.cal and load it into the field calculator and it should split the code block (lines --1-13 from the expression (line 15).  Just remember to change the !Test! fieldname to match your field containing the source data.
If you prefer to copy/paste/retype, then put lines 1-13 into the code block and line 15 in the expression
JoshuaBixby
MVP Esteemed Contributor
You had a question but posted it as a discussion, which likely contributed to the low response.  It is best to mark questions as questions.  Also, you could share your question with the https://community.esri.com/community/developers/gis-developers/python?sr=search&searchId=723a7387-b0...‌ place to increase the visibility and possibly get more and quicker responses.
DustinHall1
You can use this setup under field calculator-
Parser: Python
Check Show Codeblock
Under Pre-logic Code Script:
d={}
def GroupOrder(groupID):
N=d.get(groupID,0);N+=1
d[groupID]=N
return N
Bottom Box:
GroupOrder (!FieldName!)
Hope this helps!
