Looking for proper syntax for SQL expression in Python to select features by attribute
3892
04-19-2017 09:36 AM
deleted-user-AOHsGDn8SRw7
I am trying to create a simple code that will select features in a shapefile based on the query {anything within the ATTRIBUTE field that starts with the letter 'P'}. Here the problematic line:
arcpy.SelectLayerByAttribute_management("NJ_Wetlands", "NEW_SELECTION", """"ATTRIBUTE" LIKE P%""")
I know I could do this simply in the toolbox GUI, but I'm trying to learn arcpy. I'm obviously doing something wrong, and it shouldn't be very complicated. I get the error:
Runtime error Traceback (most recent call last): File "<string>", line 1, in <module> File "c:\program files (x86)\arcgis\desktop10.5\arcpy\arcpy\management.py", line 7713, in SelectLayerByAttribute raise e ExecuteError: ERROR 000358: Invalid expression Failed to execute (SelectLayerByAttribute).
I've already tried searching through various forums and some help guides on Esri.com, but no dice. I guess I need this help to be explained very explicitly, otherwise I am lost.
JoshuaBixby
MVP Esteemed Contributor
How about:
arcpy.SelectLayerByAttribute_management("NJ_Wetlands", "NEW_SELECTION", "ATTRIBUTE LIKE 'P%'")
Since you are wanting to learn Python, I encourage you to read String literals section of the Lexical analysis Python documentation.
Thank you, it worked like a charm!
JoshuaBixby
Please mark an answer correct to close out the question, thanks.
