da.InsertCursor - Empty Polygon Geometry
2504
01-31-2019 06:28 AM
ChiZhang2
I need to take vertex coordinates and draw them as polygons using da.InsertCursor. However, it is giving me random results. The script keeps running but many features show empty geometry:
Here is the code I use with 2 ticket examples - one can be inserted with geometry but the other one not.
# Define Ticket
class Ticket(object):
    id = 0
    coordinates = ""
    cleanCoordinates = []
    def __init__(self, id):
        self.id = id
# Sample tickets
ticket1 = Ticket(30190000001)
ticket1.coordinates = "39.938690/-75.153437,39.938634/-75.152868,39.936101/-75.153427,39.936228/-75.153883"
ticket1.cleanCoordinates = [c.split("/") for c in ticket1.coordinates.split(",")]
ticket2 = Ticket(30190000002)
ticket2.coordinates = "40.013851/-75.200242,40.015240/-75.198461,40.017056/-75.201218,40.015774/-75.203267,40.015158/-75.204930"
ticket2.cleanCoordinates = [c.split("/") for c in ticket2.coordinates.split(",")]
resultsPolygon = [ticket1, ticket2]
# Delete old features in the table
ticketPolygonTrack = "PAOneCall_Boundary_Track_test"
arcpy.DeleteFeatures_management(ticketPolygonTrack)
# Insert tickets
ticketPolygonTrackFields = ["POCS_NUMBER", "SHAPE@"]
cursorPolygon = arcpy.da.InsertCursor(ticketPolygonTrack, ticketPolygonTrackFields)
for j in resultsPolygon:
    print("Polygon: " + str(j.id))
    array = arcpy.Array()
    pointObject = arcpy.Point()
    for coords in j.cleanCoordinates:
        pointObject.X = float(coords[1])
        pointObject.Y = float(coords[0])
        array.add(pointObject)
    polygonObject = arcpy.Polygon(array)
    row = (str(j.id), polygonObject)
    cursorPolygon.insertRow(row)
del cursorPolygon
print("Finished.")‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Here is the results for this script:
The feature class projection is WGS 1984.
Any help would be appreciated. Thanks!
HuShao1
Hi Chi,
The polygon geometries were not correctly created in your script. If you print the polygons as WKT, you will find the first one is empty (I deleted the inserting actions here):
import arcpy
import arcpy
# Define Ticket
    id = 0
    coordinates = ""
        self.id = id
# Sample tickets
    print(polygonObject.WKT)
print("Finished.")
Polygon: 30190000001
MULTIPOLYGON EMPTY
Polygon: 30190000002
MULTIPOLYGON (((-75.19927978515625 40.01470947265625, -75.201171875 40.01708984375, -75.20379638671875 40.01507568359375, -75.19927978515625 40.01470947265625)))
Finished.
Adding the spatial reference when creating the polygon will solve this issue. since the projection is WGS 1984, the spatial reference code is 4326.
# Define Ticket
    id = 0
    coordinates = ""
        self.id = id
# Sample tickets
spatial_reference = arcpy.SpatialReference(4326)
    polygonObject = arcpy.Polygon(array, spatial_reference)
print("Finished.")
MULTIPOLYGON (((-75.15343699999994 39.938690000000065, -75.153882999999951 39.936228000000028, -75.153426999999965 39.936101000000065, -75.152867999999955 39.938634000000036, -75.15343699999994 39.938690000000065)))
MULTIPOLYGON (((-75.200241999999946 40.013851000000045, -75.198460999999952 40.015240000000063, -75.201217999999983 40.017056000000025, -75.203266999999983 40.015774000000079, -75.204929999999933 40.015158000000042, -75.200241999999946 40.013851000000045)))
Finished.
HuShao1
Hi Chi,
import arcpy
import arcpy
# Define Ticket
    id = 0
    coordinates = ""
        self.id = id
# Sample tickets
print("Finished.")
MULTIPOLYGON EMPTY
Finished.
# Define Ticket
    id = 0
    coordinates = ""
        self.id = id
# Sample tickets
print("Finished.")
Finished.
ChiZhang2
It works. Thanks!!
RandyBurton
Thanks. From your code example, I used this in a project:
if "EMPTY" not in polygonObject.WKT:
    # do something‍‍
JoshuaBixby
MVP Esteemed Contributor
In terms of style, you can use generator expressions and nested functions to condense the code.  For example, the following
 with
            arcpy.Array(arcpy.Point(x,y) for y,x in j.cleanCoordinates),
WeiZhao
When created with arcpy.Polygon(), the geometry is  low-precision. Applying SpatialReference to geometry will solve the null geometry problem.
