Arcpy error.
7848
8
04-21-2020 08:07 AM
EmmaAppel
I am currently trying to write a script that iterates through files in a folder to do geoprocessing. However, I am getting held up at the very start of my code with an error I cannot explain or find an answer to. I am basically a novice at Python scripting, however, I have used arcpy and pyscripter successfully throughout my schooling to run moderately complex scripts and have never seen this error before.
This is the error I am getting:
ERROR: File "c:\program files (x86)\arcgis\desktop10.7\ArcToolbox\Toolboxes\kml_to_shp.py", line 20, in <module>
kmlFile = sys.argv[1] # kml file
<type 'exceptions.IndexError'>: list index out of range
E:\ScalesCNPP\START\GPS TRACKS\BALA\MK\KML
This is my script:
I should also mention that when I try to set arcpy.env.workspace it seems to be failing after I type in the "arcpy.env." "workspace" does not show up in the autocomplete list so I truly have no idea whats going on.
JakeSkinner
Esri Esteemed Contributor
Hi Emma,
I'm curious if you try another directory for arcpy.env.workspace will you receive the same error?  For example, try:
arcpy.env.workspace=r"E:\ScalesCNPP"
EmmaAppel
Hi Jake,
I get the exact same error no matter what I set the workspace as. It appears that setting the workspace environment isn’t working at all. It might be a problem with the version of python / pyscripter, howevere it has been working fine until today and I haven’t changed anything so I don’t know.
Sent from Mail<https://go.microsoft.com/fwlink/?LinkId=550986> for Windows 10
JakeSkinner
If you run the code in ArcMap/ArcGIS Pro, do you receive the same error?
EmmaAppel
I can run the code fine in ArcMap python window, its just when i’m using pyscripter. Im not great at running command line code, and its something I want to replicate over at least 10 folders so would like to be able to just write and edit in pyscripter where its easier to edit. I have even tried unistalling pyscripter, and reinstalling it. Honestly have no idea why its happening. It gives me the same error even when I just have “ import arcpy”
JakeSkinner
Check what version of Python PyScripter is running.  You can do this by clicking on the Python Versions tool in PyScripter:
Choose Setup Python Versions.  What is listed under your Registered Versions?
EmmaAppel
Currently Running Python 2.7(32bit). Which by my understanding is the correct one to be using with arcmap because it doesn’t work with the newer ones?
JakeSkinner
What is the path to your python 2.7 version?  See my screen shot above.
EmmaAppel
Here is my python path.
