arcpy.DeleteVersion_management - ERROR 000301
3982
12
10-31-2018 08:16 PM
WangTsai
Hi All,
I am trying to use arcpy on ArcCatalog 10.2.1 to delete some version on our sql database. when I use the function arcpy.DeleteVersion_management(connection, version.name), i get an error "ERROR 000301: The workspace is of the wrong type". The connection is to a .sde file and the user has permission to delete all versions.
Thank you for your help
Below is my script:
arcpy.env.Workspace = r'C:\Users\JBurgos\AppData\Roaming\ESRI\Desktop10.2\ArcCatalog\ArcGIS to BELNetwork.sde'
defaultVersion = "sde.DEFAULT"
connection = arcpy.env.Workspace
versionName = "WR456_DN560"
arcpy.ClearWorkspaceCache_management()
# Execute DeleteVersion
for version in arcpy.da.ListVersions(connection):
    try:
    print "Found - {0}".format(version.name.split(chr(34) + ".")[1])
    currentversion = format(version.name.split(chr(34) + ".")[1])
    except:
try:
            print "Found - {0}".format(version.name.split(".")[1])
            currentversion = format(version.name.split(".")[1])
except:
            print "Found - {0}".format(version.name.split(".")[0])
            currentversion = format(version.name.split(".")[0])
    if currentversion == versionName:
        print("Attempting to Delete version {0}".format(version.name))
        print("Deleted version {0}".format(version.name)) Print ("Done")
WangTsai
I added the apostrophe to the name but I get the same error.
arcpy.DeleteVersion_management(connection, '\'' + version.name + '\'')
JoeBorgione
What exactly are you trying to accomplish with this?
WangTsai
To add apostrophe. I have also tried with the combination of double quotation and single quotation: " ' " + version.name + " ' "  Still didn't work.
