ClearWorkspaceCache: For Your "This Should Work. Why Isn't It Working?" Needs
1504
07-29-2025 01:31 PM
JeffreyThompson2
MVP Frequent Contributor
3 4 1,504
I have been struggling for several days trying to convert a legacy Python 2/ArcMap based script to run in the Python 3/ArcPro environment. It is a multi-step, data management script that involves clearing out the old data and putting in the new data. The script kept failing before a call to TruncateTable with "ERROR 000187: Only supports Geodatabase tables and feature classes." and/or at Compact with "ERROR 000535: Workspace does not exist." This didn't make sense since the data being feed to TruncateTable was a feature class and the Workspace being compacted did exist. And this script works just fine in the ArcMap runtime.
We figured pretty early on that it was probably some sort of data locking issue or possibly something to do with the file path names being interpreted differently in the different flavors of Python. We tried writing our file paths differently, explicitly starting and stopping an edit session, and a bunch of other stuff. None of that worked.
Then, I found a StackExchange answer that mentioned ClearWorkspaceCache. I threw arcpy.management.ClearWorkspaceCache() on the line before the TruncateTable and Compact calls and the script just worked. So the data was in fact being locked by the caching.
Moral of the story: If you have a script that doesn't work and you don't know why and it's giving you errors that don't make sense, try ClearWorkspaceCache().
4 Comments
BlakeTerhune
I have included this at the end of most of my scripts because of this portion of the documentation:
To clear the workspace cache in a Python script, use this tool as the final call in the script. Use the Python del statement to delete all references to objects or variables that may be pointing to the workspace before calling this tool.
It sounds like you have used it in the middle of your script to solve the issue. I will try to remember this as a possible intermediate process too. Thanks!
HaydenWelch
MVP Regular Contributor
Something else you can do is wrap your whole script in a function then call that function. That way the script scope doesn't pollute the root namespace when it runs:
# Bad
PATH = '<Some Path>'
x = arcpy.SomeFunction()
y = arcpy.SomeOtherFunction()
del x
del y
arcpy.ClearWorkspaceCache()
# Good
def main():
if __name__ == '__main__':
    try:
        main()
    finally: # <- del is called on everything in the main() scope here
#Best
def clear_cache(func):
    def _wrapped(*args, **kwargs):
        try:
            return func(*args, **kwargs)
        finally: # <-runs after return or on exception
    return _wrapped
@clear_cache
def foo():
    arcpy.SomeFunc()
@clear_cache
def bar():
    arcpy.SomeOtherFunc()
@clear_cache
def main():
    x = foo()
    y = bar()
    # ClearCache is now called after every function with the decorator
    # and one last time after main() is called
    main()
BlakeTerhune
@HaydenWelch, I've been doing the "good" option with ClearWorkspaceCache() in the finally block. I like the decorator idea though. Thanks!
JordanBaumgardner
I had a script that kept running into locks on the fgdb when it would go to zip, move, or remove. Normal things didn't seem to clear it out. This ended up clearing its little brain.
finally:
	# Release locks so the FGDB can be zipped or moved by the Files stage
	try:
		# Drop any workspace refs
		arcpy.env.workspace = None
		arcpy.env.scratchWorkspace = None
	except Exception:
		pass
	try:
		arcpy.ClearWorkspaceCache_management()
	except Exception:
		pass
	try:
		# Refresh the catalog to release lingering handles on the FGDB
		arcpy.RefreshCatalog(self.output_fgdb)
	except Exception:
		pass
	# Encourage Python to drop file handles held by garbage
	gc.collect()
	# Small delay helps some environments finish releasing locks
	time.sleep(0.25)
Contributors
About the Author
A frequently confused rock-hound that writes ugly, but usually functional code.
