Write records to csv
2972
14
11-28-2011 04:23 AM
DaveJordan1
My ultimate goal is to create mailing labels from selected parcel polygons. using the following code I am attempting to write out to a txt file the selected records. It works but I am having issues with the output it is giving me.
1) before each field that contains a string value it is inserting the letter "u".
2) I want to remove the quotes from each field and the brackets.
3) If there is a better way to do this, please let me know
Here is the code followed by a sample of the output
import arcpy
from arcpy import env
try:
mxd = arcpy.mapping.MapDocument("Current")
df = arcpy.mapping.ListDataFrames(mxd, "ParcelDF")[0]
Parcels = "parcels"
fc = arcpy.mapping.ListLayers(mxd, Parcels, df)[0]
f = open("Y:\Notification Radius Pkgs\Setup10\Test.txt", 'w')
# Create a search cursor
rows = arcpy.SearchCursor(fc)
# Create a list of fields
fields = arcpy.ListFields(fc, "", "")
# Write the output to a text file
record = [""]
for row in rows:
for field in fields:
if field.type != "Geometry":
#print "%s: Value = %s" % (field.name, row.getValue(field.name))
record.append(row.getValue(field.name))
f.writelines("%s\n" % record)
record = [""]
f.close-------------------------------------------------------------------------
SAMPLE OUTPUT
[' ', 27521, u'24', u'37', u'22', u'01', u'B', u'7', 0, u' ', u' ', 0.59999999999999998]
JakeSkinner
Esri Esteemed Contributor
Hi Dave,
You can do this by iterating through each item in your list.  Add the following to your script:
import arcpy
Parcels = "parcels"
rows = arcpy.SearchCursor(fc, "OBJECTID < 5")
fields = arcpy.ListFields(fc)
record = []
for row in rows:
            ##print "%s: Value = %s" % (field.name, row.getValue(field.name))
            for item in record:
                   f.writelines("%s\n" % item)
            record = []
f.close()
del row, rows
DaveJordan1
Thank you for taking time to look at this.  Your suggestion does clean up the output, but it prints each field value in the record to a newline.  I need each value to be separated by a comma and each record to a newline...
example:
24, 37,  22', 01, B, 7, 0, , , 0.59999999999999998
24, 37,  22', 01, B, 8, 0, , , 0.59999999999999998
24, 37,  22', 01, B, 9, 0, , , 0.59999999999999998
JakeSkinner
There may be an easier way, but I was able to accomplish this by writing each field to the output text file.  Ex:
import arcpy
Parcels = "parcels"
for row in rows:
            f.write(str(row.getValue("OBJECTID")) + ", " + str(row.getValue("LU_CODE")) + ", " + str(row.getValue("ZONE_CODE")) + "\n")
f.close()
del row, rows
DaveJordan
Jake,
I've spent the better part of the day trying to get this to work.  I keep thinking that I must be missing something.  Its failing on the WRITE statement.  I've simplified it down to just a single field (OBJECTID) for testing.   Here is the error I am getting:
Running script Test...
  File "C:\Dev\ArcGIS10\Python\DaveTest.py", line 44, in <module>
    f.write(str(row.getValue("OBJECTID")) + "\n")
  File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\arcobjects\arcobjects.py", line 945, in getValue
    return convertArcObjectToPythonObject(self._arc_object.GetValue(*gp_fixargs(args)))
RuntimeError: ERROR 999999: Error executing function.
Completed script Test...
Failed to execute (Test).
MathewCoyle
Honored Contributor
Hi Dave, I tested Jake's script and it works fine for me. Are you using proper syntax/indentation? Is there a field called "OBJECTID"? Do you have write access to that directory on Y-drive? Not sure what would be causing this issue.
Try something simple like
rows = arcpy.SearchCursor("parcels")
for row in rows:
    print row.getValue("OBJECTID")
Then add on line by line until you run into a wall.
JakeSkinner
Hi Dave,
Feel free to post your entire block of code.  Be sure to wrap it in
 tags (using # symbol above) to preserve indentation.
DaveJordan1
Here is the entire code:
import arcpy
try:
  Parcels = "parcels"
  rows = arcpy.SearchCursor(fc,"","","TOWNSHIP; RANGE; SEC; SUBCODE; BLOCK; LOT","")
  for row in rows:
# Previous attempts-
#      f.writelines(str(row.getValue("TOWNSHIP")) + ", " + "\n")
#  (row.getValue("TOWNSHIP") + ", " str(row.getValue("RANGE")) + ", " + str(row.getValue("SEC")) + ", " + str(row.getValue("SUBCODE")) + ", " + str(row.getValue("BLOCK")) + ", " + str(row.getValue("LOT")) + "\n")
  f.close()
  del row, rows
except Exception, e:
  import traceback
  f.close
  map(arcpy.AddError, traceback.format_exc().split("\n"))
  arcpy.AddError(str(e))
MathewCoyle
Honored Contributor
Oh, your field limiters are taking out OBJECTID...
Oh sorry, after testing even that should work, I guess OBJECTID is protected from field limiters. Not sure what your issue is, works fine even with the non raw path and improper indentation.
DaveJordan1
for row in rows:
I tried your sample also.  It gives the same 99999 useless error.  I believe I am using the proper indentation.  Yes there is a field called OBJECTID and yes I have write permission to the directory.
Extra info - I have kept it simple for development purposes, There is only one data frame and one feature class (parcels) in this mxd.
I have successfully written out individual values from fields in the row using - For Field in Fields -
Thanks for helping with this.
