arcpy.mapping.ListDataFrames - why the array index [0] on the end?
1977
12-01-2011 11:41 PM
JT2
Can someone please explain why we need to do this:
df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0]
instead of just:
If I just say
df = arcpy.mapping.ListDataFrames(mxd)
then I can loop through the df list object by doing something like
for i in df:
  print i.name
But if I want to set variable df to a known data frame (in this case "Layers") why do I need to specify the index number [0] at the end of the code line?
If anyone can explain this quirk I'd be really grateful. Thanks
AndrewChapkowski
It's not a quirk, the function returns a list object.  In order to access the underlying data inside the list, you need to tell the object what information you need by letting the list know I want some piece of information in position X.
To be even more general, functions return a specific data type.
Hope this helps.
ScottOatley
You don't. Without [0], df is a list of data frames, regardless of whether you explicitly specify a data frame, e.g. "Layers." Consider if there are multiple data frames with the same name. Of course, with [0] - or generally , df is a single data frame.
"Layers" is merely a filter that removes any data frames not named "Layers."
Scott
JT2
OK Thank you. I understand, so it's basically Python syntax, being the difference between a list object, and an individual member of that list, indexed by the square brackets []
Presumably if I had two data frames called "Layers" then I could index them using [0] and [1]?
ArkadiuszMatoszka
Correct 🙂
