Write polyline vertices to csv
5283
04-10-2014 06:27 AM
TonyAppel1
I am looking for some code to write out each line feature in a feature class/shapefile to a csv file that would look something like this:
FID, X, Y
All help is appreciated.
thanks
Tony
JakeSkinner
Esri Esteemed Contributor
Hi Tony,
You could perform the following steps:
1.  Convert the lines vertices to a point feature class using Feature Vertices to Points
2.  Add XY Coordinates to point feature class
3.  Export feature class to dbf file
4.  Rename output dbf file to csv using os.rename
Zeke
Honored Contributor
You could also use the python csv module to write the file out.
MattEiben
A search cursor like this could easily iterate through all the points and add them to a csv file for you.
The key here is to use the "explode to points" method in the search cursor
import csv
with arcpy.da.SearchCursor(featureClass, ["OID@","SHAPE@XY"],explode_to_points=True) as cursor:
    with open("outputFile.csv","wb") as csvfile:
        writer = csv.writer(csvfile)
        writer.writerow(["FID","LAT","LON"])
        for row in cursor:
            FID = row[0]
            lat = row[1][1]
            lon = row[1][0]
            writer.writerow([FID,lat,lon])
Hope this helps!
Matt
MatthewDobson
I am not sure, but will the 'Export Feature Attribute to ASCII' tool do the trick?
I found it under Spatial Statistics -> Utilities ....
Matthew
