Would like to create star and snowflake symbols
4641
10-28-2015 04:10 PM
SteveCline
I am trying to replicate a technique used in the attached photo which uses what they call, "star and snowflake symbols" for multivariate analysis.  Is there any functionality in Desktop that might accomplish this or a similar visualization?
Source: Slocum, T. A., McMaster, R. B., Kessler, F. C. and Howard, H. H. 2005. Thematic Cartography and Geographic Visualization, Prentice‐Hall. 2nd edition (p. 355)
DarrenWiens2
Here's how you can do it with arcpy geometries (10.1+):
>>> fc = "grid" # input feature layer
... sr = arcpy.Describe(fc).spatialReference # spatial ref
... points = []
... lines = []
... polys = []
... fields = ["SHAPE@","var1","var2","var3","var4","var5","var6","var7","var8"] # geometry plus 8 variables
... maxDist = 5 # value multiplier
... with arcpy.da.SearchCursor(fc,fields,spatial_reference=sr) as cursor: # loop through features
...     for row in cursor:
...         centre = row[0].centroid # centre point
...         newPolyPoints = []
...         for i in range(1,9): # loop through variables
...             x = centre.X + math.cos(math.radians(i*45))*row*maxDist # x offset
...             y = centre.Y + math.sin(math.radians(i*45))*row*maxDist # y offset
...             newPoint = arcpy.PointGeometry(arcpy.Point(x,y),sr) # create point geometry
...             points.append(newPoint)
...             newLine = arcpy.Polyline(arcpy.Array([centre,newPoint.centroid]),sr) # make ray lines
...             lines.append(newLine)
...             newPolyPoints.append(newPoint.centroid)
...         newPoly = arcpy.Polygon(arcpy.Array(newPolyPoints),sr) # make snowflake polygon
...         polys.append(newPoly)
... arcpy.CopyFeatures_management(points,r'in_memory\points') # write points
... arcpy.CopyFeatures_management(lines,r'in_memory\lines') # write lines
... arcpy.CopyFeatures_management(polys,r'in_memory\polys') # write polygons
DanPatterson_Retired
No but easy to replicate using python and matplotlib there are variants by name and specifics (aka radar, star)
api example code: radar_chart.py — Matplotlib 1.4.3 documentation in essence, you need magnitude and direction data and in your case, you join the points on the outer bounds rather than back to the center.
Be careful about the term star graph, since it also comes from a portion of graph theory, which probably isn't what you want... Star Graph -- from Wolfram MathWorld
Besides their snowflake is so lame, you can expand to variants raspberrypilearning/turtle-snowflakes · GitHub or even take it into fractal space
Some sample data would be useful
DarrenWiens2
... points = []
... lines = []
... polys = []
Nice!!! remember this one next time someone asks a boring buffer question
SteveCline
Thank you.  That is exactly what I need to do.
