Workspace describe.connectionProperties vs Layer.connectionProperties
1381
08-01-2022 02:31 PM
YinghongLi1
I am confused by these two.  They may contain similar information but the ways to get the values out of them seem a bit different.
The Pro help states clearly:  Layer.connectionProperties is a layer's data source connection information as a Python dictionary.   Workspace describe.connectionProperties is a property set
I do not understand the difference of getting values out of them.  See sample code below.  Thanks.
Here is the sample code to get layer connection properties:
conn_prop=layer.connectionProperties
conn_info=conn_prop['connection_info']  #db_connection_properties']
instance =conn_info['db_connection_properties']  #giswpddev
print(conn_info)
version=conn_info['version']
print (version)
print(instance)
Print(conn_prop)
Here is the sample code workspace describe connection properties:
desc=arcpy.Describe(workspace_sde)
print("%-24s %s" % ("Connection String:", desc.connectionString))
print("%-24s %s" % ("WorkspaceFactoryProgID:", desc.workspaceFactoryProgID))
print("%-24s %s" % ("Workspace Type:", desc.workspaceType))
cp = desc.connectionProperties
print(cp)   #this return an empty object
print("\nDatabase Connection Properties:")
print("%-12s %s" % ("  Server:", cp.server))
print("%-12s %s" % ("  Instance:", cp.instance))
#print("%-12s %s" % ("  Database:", cp.database))
print("%-12s %s" % ("  User:", cp.user))
print("%-12s %s" % ("  Version:", cp.version))
JoshuaBixby
MVP Esteemed Contributor
I think you do understand the different ways of getting information out of them because you have provided sample code demonstrating how to extract connection properties from both.  If your confusion is why these are different, I think the answer is because they were developed at different times, using different parts of Pro's underlying code, and there is no requirement that connection property information has to be returned in a single format.
JoshuaBixby
