Will anything in "with arcpy.da.SearchCursor(fc,fields,'1=2') as cursor" execute?
1046
03-08-2013 08:14 AM
StormwaterWater_Resources
Does a "with" block always execute even when passed an empty cursor?
For testing purposes I've tried this:
with arcpy.da.SearchCursor(fc, "ST_ID", "1=2") as cursor:     arcpy.AddMessage("In the With")     try:         test = cursor.next()         arcpy.AddError("ERROR:  There is more than one ...")         sys.exit(1)     except StopIteration:         arcpy.AddMessage("All is good, there's one and only one ...")         pass
Note the "where" clause.
I'm expecting this search cursor to return 0 or 1 rows.  I was thinking that the "with" block would only be executed if I had a row.  Then my intent with the "try" was to catch a 2nd row which I shouldn't ever have.
However in testing this I realized I'm always going into the with block.  To be sure I put in the False where clause.  Even with that where clause I'm seeing the "In the With" statement in my results window.
I'm trying to wrap my head around the with statement, but even though others have said I have a big head it's not fitting...
PS: or am I not understanding something about the search cursor?
JimCousins
Yes, a with statement will always step in, attempt the try, and move into the except as necessary. For a deeper explanation: http://effbot.org/zone/python-with-statement.htm
curtvprice
If you don't expect a lot of rows, GetCount would probably be very quick for this test:
numRows = int(arcpy.GetCount_management(fc).getOutput(0))
if numRows == 1:
else:
    arcpy.AddError("All is not good: {0} rows found".format(numRows))
This worked for me too:
with arcpy.da.SearchCursor(fc, "ST_ID") as cursor:
    try:
        arcpy.AddMessage("Got one.")
        test = cursor.next() # try get a second row
        sys.exit(1)
    except:
        arcpy.AddError("Something else happened!")
JimCousins
