Wildcards?
2890
6
05-23-2011 06:53 AM
PaulBoehnlein
I have a group of raster datasets, some .Tiff's, some .jpg's.  I want to perform arcpy.ImportMetadata_conversion on them.  I recall doing something similar in Windows command line using something like...
FOR %f in (*.tif) DO arcpy.ImportMetadata_conversion(example.xml, *.tif)
I think that's called a wildcard?  Is there something equivalent I can do in Python?  Could someone show me an example?  Please forgive my newbieness.
JasonScheirer
Esri Alum
You can use glob.
import arcpy
import glob
import os
directory = r"c:\tiffs\"
for tif in glob.glob(os.path.join("*.tif")):
    arcpy.ImportMetadata_conversion("example.xml", tif)
PaulBoehnlein
Jason,
Thanks for the reply. Your directory path has a slash at the end; that gives me a syntax error in IDLE. When I remove the slash (see below), the script runs, but the metadata file does not get imported. Any thoughts?
import os, sys, traceback, string, arcpy, glob
try:
    directory = r"C:\Rectified Inundation Maps"
        arcpy.ImportMetadata_conversion(r"C:\Rectified Inundation Maps\contact_PMI_maps.xml", tif)
    print "Import finished."
JasonScheirer
Esri Alum
Oh, whoops. needs to be
directory = r"c:\tiffs\\"
PaulBoehnlein
That corrects the syntax error, but it still doesn't work. Any other suggestions?
LoganPugh
I think maybe Jason just forgot to use the directory variable in the os.path.join function. And you do not need trailing slashes when using os.path.join. This should work:
import arcpy
import glob
import os
directory = r"c:\tiffs"
for tif in glob.glob(os.path.join(directory, "*.tif")):
If you need a recursive function (goes into all subdirectories of the initial directory), take a look at some of these examples: http://stackoverflow.com/questions/2186525/use-a-glob-to-find-files-recursively-in-python
PaulBoehnlein
Thanks so much Logan.
