Why Runtime error EOF when reading a line with INPUT function
3436
01-17-2012 01:47 AM
CarmeCaum
Hi everybody,
I need to program a function that asks to the user for the values of some of its parameters.
I simply wrote and execute the Python prompt from ArcGIS 10:
x= input("Enter the number of rows")
I get:
Runtime error <type 'exceptions.EOFError'>: EOF when reading a line
It is really strange because it works correctly in Python 2.6 that has been installed with ArcGIS 10.
Any ideas?
Thanks in advance!
Carme
JakeSkinner
Esri Esteemed Contributor
Hi Carme,
If you are creating a custom tool to use within ArcMap, you should consider using the arcpy.GetParameterAsText function.  Here is some further information on how to set a script tool's parameters.
CarmeCaum
Hi!
Good point...I hadn't realized that it was that great tool...thanks 🙂
Carme
