Why is my script running fine with one feature class but does not run correctly with multiple feature classes?
2153
10-25-2016 02:56 PM
TravisPreston2
The purpose of the script is to count the number of single family homes within each "FireBoxMap" feature class. When I specify a single feature class in line 10 the script runs fine. When I change the feature class to "FireBoxMap*" to run through all of the feature classes it does not populate the desired information. I am not sure what I am doing wrong.
Thank You
LesiMai3
Travis,
You may want to move lines 22-24 in front of the for statement and wrap lines 26-37 inside the for statement.
Lesi
LesiMai3
Travis,
Lesi
JonathanQuinn
Esri Notable Contributor
If you print fcBoxZones after running arcpy.ListFeatureClasses, does the list appear correct?
LukeWebb
The question is already answered, but I will write a bit more detail to hopefully help you understand:
You have a "For" Loop, but inside the loop you only have the lines of code:
print fc
# Add two fields to hold the results
arcpy.AddField_management (fc, "SFCount", "LONG")
arcpy.AddField_management (fc, "MFCOUNT", "LONG")
The rest of the code is not indented, so does not get included in the loop!
So your script currently works as follows:
For each FC:
      print FC
      add fields to FC
On the last FC in the loop only:
selection  + calculate
To fix, simply indent all code after your "For" loop
