Why is my IF statement being ignored?
3650
03-01-2011 01:38 AM
LeeMusto
I'm sure there is a simple answer, but it seems to be beyond my limited Python knowledge. I have some very large text files, in which data is arranged in columns. One of the attributes is 'Month' and I want to create a new txt file for each month. My code is as follows:
infile = open(r"P:\Months_Test.txt")
mth = 1
for inlines in infile.readlines():
    if str(mth) in inlines[-2:]:
       outfile = open(r"P:\Month_" + str(mth) + ".txt", 'a')
       outfile.write(inlines)
       outfile.close()
    else:
       mth += 1
infile.close()
If I run this code without the ELSE statement, it correctly outputs the month 1 data into the month 1 text file. However, as soon as I add the ELSE statement, it skips the IF statement completely and just counts the number of lines in the text file (I checked by printing mth). What am I doing wrong?
LeeMusto
OK - just realised I should use 'For mth in range(1,13):' to solve problem. But, would still like to know why the IF statement wasn't working.
Also, why does this work:
'if str(mth) in inlines[-2:]:'
but, this doesn't:
'if str(mth) == inlines[-2:]' (Returns nothing)
The 'in' function will work if there are only 9 months, but runs into trouble for months 10-12.
LoganPugh
For pure Python questions I recommend StackOverflow.com. You will generally get answers within minutes of asking a question. This forum is more for ArcGIS-specific Python usage and is far less trafficked than SO.
In regards to your question I can only suggest to step through it in a debugger or sprinkle it with print statements so you are aware of the flow of control and variable contents at any point during execution.
JasonScheirer
Esri Alum
When you iterate over a file, each line gives you the final return at the end, you'll need to do something like this:
if str(mth) in inlines.rstrip()[-2:]
Otherwise line[-2:] is equal to "\r\n" and not your number (which is at [-4:-2])
