Why doesn't ArcMap think I'm starting an edit session?! =(
3448
8
01-03-2017 10:39 AM
by Anonymous User
Not applicable
okay peeps. Help me, a well-meaning state employee, out. 😃  Why do I keep getting:
from this?! =(
DarrenWiens2
Can you try printing workspace to make sure it's what you want? I think by using os.path.dirname you're backing up to the ArcCatalog folder, but you actually want it to be the .sde, at least according to the example here.
DarrenWiens2
by Anonymous User
Not applicable
You're right. It goes to C:\Users\joanna.grossman\AppData\Roaming\ESRI\Desktop10.4\ArcCatalog.
MitchHolley1
I thought we already solved this problem.
by Anonymous User
Not applicable
we did. It came back with persistance. =(
MitchHolley1
edit = arcpy.da.Editor(filepath)
by Anonymous User
Not applicable
hmmm. Thanks.
by Anonymous User
Not applicable
When I change it to that I can't access my data layer which is why I moved away from it. It throws
by Anonymous User
Not applicable
Just FYI. I had to change it back again to get it to work. I'll keep it commented out this time just in case, tho. I appreciate your help.
