Want to dissolve adjacent polygons but no common edges.
1502
05-08-2013 11:55 AM
HaoLiu1
I have a bunch of parcel data, I want to join the polygons basing on the same owner name.
Even they are not touched, I want merge them together, such a 100 feet tolerance. The purpose is to show the somebody's properties without too much separated lines.
Like this
[ATTACH=CONFIG]24139[/ATTACH]
I have some programming experience, but just start to try to get the tool by python script, and tried arcgis add_in wizard.
If there is some idea about the script work flow, it will be really helpful!
HaoLiu1
Or is there anyway that I can view the source code of dissolve or merge process tool?
ChrisPedrezuela
cant you just use Dissolve it using owners name attribute and just indicate multipart output.
