Wait for AddField to finish until running CalculatField
4828
10
04-14-2017 06:05 AM
TimWitt2
Hey everybody,
I am creating python toolbox and one of the tools adds a bunch of fields to a feature class that the user chooses and after wards calculates those fields with values from the original feature class. I run into the issue that the field calculations can't run because the fields haven't been added yet.
This is the code I use:
import arcpy
class Toolbox(object):
    def __init__(self):
        """Define the toolbox (the name of the toolbox is the name of the .pyt file)."""
        self.label = "My first python toolbox"
        self.alias = "Examples"
        # List of tool classes associated with this toolbox
        self.tools = [Tool1]
class Tool1(object):
    def __init__(self):
        """Define the tool (tool name is the name of the class)."""
        self.label = "Nena Street Tool"
        self.description = "Example showing how to create a value table tool with drop downs"
        self.canRunInBackground = False
    def getParameterInfo(self):
        """Define parameter definitions"""
        # Define Parameter 0
        # Param0 will be a FeatureLayer
        param0 = arcpy.Parameter(displayName = "Your Street Layer",name="Site_layer",datatype="GPFeatureLayer",parameterType="Required",direction="Input")
        # Define Parameter 1
        param1 = arcpy.Parameter(displayName = "",name="Activity_layers",datatype="GPValueTable",parameterType="Optional", direction="Input")
        param1.columns=[["String","NENA Field"],["String","Your Field"]]
        # This says the filter on the second column will be a value List
        param1.filters[1].type="ValueList"
        param1.value = "Source; Updatedate; Effective; Expire; RCL_NGUID; AdNumPre_L; AdNumPre_R; FromAddr_L; ToAddr_L; FromAddr_R; ToAddr_R; Parity_L; Parity_R"
        # This adds a dummy value to the list, this will get overwritten by the updateParameters function
        param1.filters[1].list=["Please Select a street layer"]
        # Create a list of parameters and return
        params = [param0,param1]
        return params
    def isLicensed(self):
        """Set whether tool is licensed to execute."""
        return True
    def updateParameters(self, parameters):
        if parameters[0].altered:
          fields = arcpy.ListFields(parameters[0].value)
          mylist = []
          for field in fields:
             mylist.append(field.name)
          parameters[1].filters[1].list = mylist
        return
    def updateMessages(self, parameters):
        """Modify the messages created by internal validation for each tool
        parameter.  This method is called after internal validation."""
        return
    def execute(self, parameters, messages):
        """The source code of the tool."""
        try:
            # Some code to show that I had managed to get what I wanted intot the ValueTable
            data = parameters[1].values
            arcpy.AddField_management(parameters[0].value, "Source", "TEXT", "", "", "75", "", "NULLABLE", "NON_REQUIRED", "")
            arcpy.AddField_management(parameters[0].value, "DateUpdate", "DATE", "", "", "", "", "NULLABLE", "NON_REQUIRED", "")
            arcpy.AddField_management(parameters[0].value, "Effective", "DATE", "", "", "", "", "NULLABLE", "NON_REQUIRED", "")
            search = 'Source'
            for sublist in data:
              if sublist[0] == search:
                final = sublist
                mysource = final[1]
                sourceData = "[" + mysource + "]"
                arcpy.CalculateField_management(parameters[0].value, "Source", sourceData, "VB", "")
                break
        except arcpy.ExecuteError:
            messages.addErrorMessage(arcpy.GetMessages())
In line 75 I add the "Source" field and in line 84 I try to calculate it, but I get the error that the "Source" field does not exist.
Any help would be appreciated.
Tim
curtvprice
You're welcome!
I will have to do that for 40 fields I am looking for any way to speed up my code.
Given your application (it sounds like you need to populate these fields from existing fields with different names, maybe parts of field content too), you may want to consider setting up a field map, add your 40 fields to it, and running Feature Class To Feature Class. Field maps are a bit tricky to work with but I'm certain this is the fastest way to add 40 fields to a table and copy content over from existing fields.
That ExtendTable thing is awesome though!
