Validate join gets ValueError: invalid literal for int() with base 10: ''
884
11-14-2023 09:57 AM
Ivy_Hinson
I pulled the validate join directly from esri but I keep getting the above error message when I run the script. When I try making the string into a float I get this error: ValueError: could not convert string to float: ''
# Join the feature layer to a table
val_res = arcpy.ValidateJoin_management(inFeatures, joinField, joinTable, joinField)
matched = int(val_res[0])
row_count = int(val_res[1])
print(arcpy.GetMessages())  # Tool messages about the Join
# Validate the join returns matched rows before proceeding
if matched >= 1:
    joined = arcpy.AddJoin_management(inFeatures, joinField, joinTable, joinField)
    # Copy the joined layer to a new permanent feature class
    arcpy.CopyFeatures_management(joined, outFeature)
DanPatterson
MVP Esteemed Contributor
Code formatting ... the Community Version - Esri Community
line numbers would help
after... val_res =
add ...
print(val_res)
It is apparently returning something that can't be converted to an integer
... sort of retired...
