Using Variable for Where Clause in search cursor
9531
03-30-2015 06:31 PM
RyanTucker1
How do I go about using a variable from a raw_input for the where clause in da.SearchCursor?
I can't seem to get the syntax correct
Code:
import arcpy
from arcpy import env
env.workspace=r"F:\GEOG_488\Final_Project_Data\FinalProject488.gdb"
fc="PARCELS" #Create variable for feature class
tc="ADDRESS_TEST_20"  #Create variable for table
HouseNumber = int(raw_input("Enter Address Number: ")) #User input House Number
print "Situs Addresses with "+ str(HouseNumber)+" for the Situs Number:"
cursor = arcpy.da.SearchCursor(tc,["ADDR"],'"SA_House_Number"= HouseNumber') #Create search cursor where records = HouseNumber
for row in cursor:
    print "Situs Address with House Number"+str(HouseNumber)":",row[0]
del row, cursor
Thanks for any help.
ModyBuchbinder
'"SA_House_Number" = ' + str(HouseNumber)
When the HouseNumber is inside the quotes it is not recognized as variable
I am not sure you have to put the attribute name (SA_House_Number) in quotes in the new versions.
DarrenWiens2
Escape HouseNumber from the where clause string.
ModyBuchbinder
JoshuaBixby
MVP Esteemed Contributor
I encourage you to learn about Python string formatting (Format String Syntax).  It is extremely robust.
cursor = arcpy.da.SearchCursor(tc,["ADDR"],"SA_House_Number = {}".format(HouseNumber))
RyanTucker1
Thank you all for your help. It now works using both the suggestion from Mody and Joshua.
I'm now reading up on string formatting.
Thanks again!
Ryan
danashney
Joshua Bixby deserves a beer or milk shake if a teetotaler.
+1 for string formatting.
