Using standard Geoprocessing Tools in python outside of ArcGIS Desktop
2187
12-01-2010 08:32 PM
DanielLozier
I have ArcGIS Deskop 10 installed on my machine and I was wondering if it's possible to create a python script that uses some standard Geoprocessing tools and run it outside of ArcGIS?
Specifically I'm trying to run the script from within my eclipse development enviroment (with Pydev installed).  I have eclipse setup to use the python installed by ArcGIS.  It's path is configured to look in C:\Python26\ArcGIS10.0\lib\site-packages and in there is the Desktop10.pth file with entries for:
C:\Program Files\ArcGIS\Desktop10.0\bin
C:\Program Files\ArcGIS\Desktop10.0\arcpy
C:\Program Files\ArcGIS\Desktop10.0\ArcToolbox\Scripts
If I try to run a script like the following in eclipse:
import arcpy
arcpy.CreateFeatureClass_management("c:/test", "test.shp", "POINT")
I get an error:
AttributeError: 'module' object has no attribute 'CreateFeatureClass_management'
JasonScheirer
Esri Alum
Arcpy is case-sensitive, use arcpy.CreateFeatureclass_management
JasonScheirer
Esri Alum
DanielLozier
Wow, ESRI needs to update their help documentation then.  The arcpy example under the Geoprocessing->The ArcPy site package->Classes->FeatureSet calls the function 'CreateFeatureClass_management'
Thanks, I would have wasted a lot of time on this.
TrungTran
Thanks.
This is really a big help. I have wasted a lot of time on this.
DanPatterson_Retired
Which is why it is always a good idea to use the online help, since it is updated
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00170000002p000000.htm
when little bugs like this are found
