Using Reclassify in Python
2279
09-13-2023 06:42 AM
SoratoMarques
I have one raster and would like to transform all values between -0,9 - 0 like 1 value, and 0 - 0,9 like NoData.
How can I to this in python?
Thank´s
DanPatterson
MVP Esteemed Contributor
Reclassify (Spatial Analyst)—ArcGIS Pro | Documentation
See the code examples for the spatial analyst extension.
... sort of retired...
HaydenWelch
MVP Regular Contributor
Have you used the arcpy.ddd.Reclassify tool yet?
From the docs:
import arcpy
# Set Environment
arcpy.env = r"<PATH TO ENVIRONMENT>"
# Set local variables
inRaster = "landuse"
field = "VALUE"
remapString = "1 9;2 8;3 1;4 6;5 3;6 2;7 1"
outRaster = "C:/output/reclass3d"
# Execute Reclassify
arcpy.ddd.Reclassify(inRaster, field, remapString, outRaster, "DATA")
In your case you would do something like this:
import arcpy
remap = "-0.9 0 1"
raster = r"<PATH TO RASTER>"
field = "<RECLASS FIELDNAME>"
out_raster = r"<PATH TO OUTPUT RASTER>"
arcpy.ddd.Reclassify(raster, field, remap, out_raster, "NODATA")
The "NODATA" flag at the end will write any values outside the provided remap range with NoData instead of the original values, so in your case you only define the remap for the lower end and just don't map the values over 0
mody_buchbinder
If you want ESRI to set the classes for you using some good algorithms you can try Slice  https://pro.arcgis.com/en/pro-app/latest/tool-reference/spatial-analyst/slice.htm
