Using code block with Field Calculator error 000539
4064
09-11-2021 04:38 PM
BenWilder
Using ArcMap 10.8.1
The following Python script ran successfully about 3 weeks ago.
I wrote the script in Notepad. Then saved it from the Field Calculator.
Load it today and I get: Error 000539: Runtime error Syntax Error: encoding declaration in Unicode string (<string>, line 0)
Notepad shows the file is encoded UTF-16 LE. I have read that Python uses UTF-8 by default. I have tried (based on suggestions on other forums) using a coding syntax like:
# _*_ coding: UTF-16 LE _*_
in first line of the Pre-Logic Script Code but that doesn't work and I don't really know what I am doing with that.
Seems like something basic is fouling the script up. Thanks for your suggestions.
Attached: screen shot of the Field Calculator window.
Script:
def Blockname(Species):
if Species = "Olneya tesota":
return "PINV-OT"
elif  Species = "Parkinsonia florida":
return "PINV-PF
elif Species =  "Parkinsonia microphylla":
return "PINV-PM
else:
return "NA"
__esri_field_calculator_splitter__
Blockname(!Species!)
DanPatterson
MVP Esteemed Contributor
Code formatting ... the Community Version - Esri Community
use Notepad ++ Notepad++ 8.1.4 release | Notepad++ (notepad-plus-plus.org)
you can set it to interpret and save a python encoded files
use UTF-8 or just dump the line period, but check the encoding to utf-8 in notepad
... sort of retired...
DanPatterson
BenWilder
Thank you, Dan!
I typically, have these files saved with the .cal extension so I can load them in Field Calculator.
I tried saving the file out of Notepad++ to a .cal file. That doesn't work.
I can copy the code block from either Notepad++ or Notepad and the script runs normally.
Thank you for pointing me in the right direction.
LukeAllen2
Hi Ben, did you ever manage to save the expression as a .cal file? I ran into this same issue today, with a field calculator expression that I've been using for the last 2 years saved as a .cal file on my desktop.
BenWilder
Hi Luke,
No, I have never been able to get saved .cal files to work. I have to copy and paste out of Notepad like Dan suggested.
Thanks for asking.
LukeAllen2
Hi, Ben (just in case you haven't already tried this) you may want to try pasting it in from notepad ++ again and just saving out a new .cal file, when I did this I no longer had issues, which made me think perhaps I unknowingly introduced something into the .cal file one time or saved it incorrectly, worth a shot if you haven't already tried. Seems to have worked for me.
Luke
