Using calculate field to sum values based on two columns, number and string
2130
03-31-2021 02:37 PM
MarilynLong1
I'm trying to use calculate field to add values to my column called Trail Length. I want to populate this column by adding together the trail sections that are part of the same trail.
Example:
Trail          Section Length      Trail Length
Trail A          .5                         (script that will add up the values in section length for Trail A, etc)
Trail A          .2
Trail B          5
Trail B           .3
Trail B           1
DanPatterson
MVP Esteemed Contributor
Summary Statistics (Analysis)—ArcGIS Pro | Documentation does it for you.  See the code sample to call it
... sort of retired...
MarilynLong1
I've used summary stats to do this in the past but how do I incorporate that into the Field Calculator? I've been trying with Python and Arcade but don't know much about scripting and can't get it to work. This is what I have with Arcade:
GroupBy($layer, 'name', { name: 'trail_ft', expression: 'sec_length_ft', statistic: 'SUM'})
'name' is the column with the names of the trails. 'sec_length_ft' is the name of the column with the length of the sections that make up the trail. 'trail_ft' is the name of the column that I want to be updated.
