user interface customizations in arcgis 10
1656
7
03-01-2011 08:56 AM
RuthEmerick
I'm looking to deploy a script to multiple users via a custom button on a toolbar in ArcMap, but I'm a bit unsure how to do this seeing as ESRI has dropped support for .mxt templates (see link below). Before, it was easy to replace a user's Normal.mxt file with a custom one that contained special toolbars/buttons. Has anyone found a workaround for this short of adding the custom button in each individual template .mxd and user created .mxd?
http://blogs.esri.com/Dev/blogs/arcgisdesktop/archive/2010/06/14/What_1920_s-new-for-map-templates-i...
Thanks in advance for any feedback from the community!
JoelCalhoun
At ArcGIS 10 ESRI has implemented add-ins as a replacement to the old .mxt model.
http://blogs.esri.com/dev/blogs/arcgisdesktop/archive/2010/05/05/add_2d00_ins-for-arcgis-desktop-10....
Also, python script tools can now be added as buttons within ArcMap and utilizing the new arcpy site package mapping module extends functionality into map document management and output.
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/Geoprocessing_scripts_for_map_document...
RuthEmerick
Thanks. The first link was very useful.
ScottOatley
Where might I find information on adding an arcpy script as a button?
Scott
JoelCalhoun
To add a geoprocessing tool or a custom python script tool as a button in ArcMap:
1) Open the "Customize" menu.
2) Select "Customize Mode"
3) Select the "Commands" tab
4) Scroll to the bottom of "Categories:" to find [Geoprocessing Tools] and select it.
5) Click the new "Add Tools..." button that appears at the bottom of the menu.
6) In the "Add Tools" popup window, navigate to the appropriate toolbox and select the desired geoprocessing/script tool.
7) In the right pane "Commands:" click hold the new geoprocessing/script tool and then drag it up to the desired toolbar.
😎 To customize the button's symbol right click on the new button in the toolbar and either select "Change Button Image" or "Browse for Image"
9) Click the Close button on the "Customize" menu .
Your geoprocessing/script tool should be ready for use.
Joel
ScottOatley
Thanks Joel, steps 1 through 7 worked perfectly and the script runs correctly. However, when I right click on the tool to customize the symbol, it brings up the standard toolbar selection menu.
Scott
JoelCalhoun
Scott
Scott,
The "Customize" window must be open for the customize options to appear when you right click the tool.
Joel
ScottOatley
I see; my bad. Got it to work.
Thank you very much!!
Scott
