USE GDAL
2256
02-21-2014 02:25 PM
HollyZhang1
I installed GDAL core and python bingings (ArcGIS10.2). There are no error massage import:
from osgeo import gdal
from osgeo import ogr
from osgeo import osr
But there are errors:
No module named ogr2ogr
ImportError: cannot import name ogr2ogr
What to do to use ogr2ogr?
Thanks.
Luke_Pinner
MVP Regular Contributor
ogr2ogr is a commandline program not a python module.  You can run it from a command prompt or you can use the subprocess module to run it from within python.
cmd=["ogr2ogr", "output_dataset", "input_dataset"]
proc = subprocess.Popen(cmd, stdout=subprocess.PIPE,stderr=subprocess.PIPE)
stdout,stderr=proc.communicate()
exit_code=proc.wait()
if exit_code: print stderr
else: print stdout
XanderBakker
Esri Esteemed Contributor
Hi Holly,
I recently did an open source project with Python and found the website below very helpful:
http://www.lfd.uci.edu/~gohlke/pythonlibs/#gdal
I installed the executable "GDAL-1.10.1.win32-py2.7.exe" and was able to use "gdal, ogr and osr" without any further pip or easy_install.
Please pay attention to the note on that page:
This distribution includes all required files. Do not use together with OSGeo4W or gdalwin32.
Kind regards,
Xander
