UpdateCursor Problem
6166
8
02-05-2016 09:13 AM
KennethKirkeby
Disclosure: Portion of my homework
The following script creates a count of wells per county and works:
import arcpy
arcpy.overWriteOutput = True
arcpy.env.workspace = "C:\\Users\\kkirkeby\\Desktop\\GIS-4080\\Lesson5_Data\\Lesson5_Data"
# Variables
wells = "Wells.shp"
counties = "COUNTIES.shp"
Wells_Intersect = "Wells_Intersect.shp"
Wells_Intersect_Layer = "Wells_Intersect_Layer"
input_f = ["Wells.shp", "COUNTIES.shp"]
# Process: Intersect
#arcpy.Intersect_analysis(input_f, Wells_Intersect, "ALL", "", "INPUT")
# Process: Make Feature Layer
#arcpy.MakeFeatureLayer_management(Wells_Intersect, Wells_Intersect_Layer)
# List County Names
countyList = [row[0] for row in arcpy.da.SearchCursor(counties, "COUNTY")]
# Count wells for each county
for cname in countyList:
    whereclause = "{} = '{}'".format("COUNTY", cname)
    wellCnt = 0
    with arcpy.da.SearchCursor(Wells_Intersect_Layer, "COUNTY",whereclause) as cursor:
        for row in cursor:
            wellCnt = wellCnt + 1
        print cname + ", " + str(wellCnt)
I need to update the second to last column in the row with wellCnt. My thought was to modify the script with the following:
forcname in countyList:
    wellCnt = 0
    with arcpy.da.UpdateCursor(Wells_Intersect_Layer, "COUNTY",whereclause) as cursor:
        for row in cursor:
        row[-2] =  wellCnt
        cursor.updateRow(row)
Error: IndexError: list assignment index out of range
Thanks for any advice or assistance.
WesMiller
To use an row index you'll need to supply the fields to your da.UpdateCursor see the help on UpdateCursor—Help | ArcGIS for Desktop
DanPatterson_Retired
Use raw notation for paths..
r"C:\\Users\\kkirkeby\\Desktop\\GIS-4080\\Lesson5_Data\\Lesson5_Data"
little r in front and next time make sure that you aren't using - or spaces... _ is ok
since it is homework
EDITS
removed the double-backslashes due to a copy error, it should read
r"C:\Users\kkirkeby\Desktop\GIS-4080\Lesson5_Data\Lesson5_Data"
from the help
fields = ['ROAD_TYPE', 'BUFFER_DISTANCE']  # Create update cursor for feature class
with arcpy.da.UpdateCursor(fc, fields) as cursor:
As indicated in the previous post, you need to provide a list of fields to the cursor.  You are trying to access the 2nd last element, however, that is why you are getting an out of range error, because, it doesn't even have a list to draw from
RebeccaStrauch__GISP
the help 10.3 -> 10.4 seems to be in place (as I tried to hit your link for my purposes...)
Accessing data using cursors—Help | ArcGIS for Desktop
UpdateCursor—Help | ArcGIS for Desktop   arcpy functions
UpdateCursor—Help | ArcGIS for Desktop    data access module
just an update....fwiw.
They are ... flakifying ... the help today... I can't even get a hit on cursors, let alone any specific type of cursor
yes... copied the wrong testing variant  double backslashes works was testing too much
Filenames and file paths in Python
EDIT
fixed the original
DarrenWiens2
As you have it now, you are only passing one field into the cursor - "COUNTY". This means that list of values in row only has one item - the county. row[0] would equal the county for that record. Change "COUNTY" to whatever the field you want to update is called. Then, it will be row[0].
Kenneth, at this stage, it would also be worth while looking at Joshua Bixby    blog... he has several on cursors and their use.  This is one, check them all  J
The Iterable Cursor:  Python Built-ins & Itertools
