Update Field from Multiple Field(s)
4930
12
09-19-2016 11:00 AM
ModernElectric
I have been looking around the internet all morning to figure out how to write a Python script to accomplish what I need to do, and so far, I am not finding what I need. Need to see if someone can start me in the correct direction.
I have (2) text fields:
   ACALARA TYPE and ACALARA MODEL with coded meter type attributes
Another field:
   ACALARA METER TYPE will hold the actual Meter Type
The data in the first two fields is held in a different database and I have a Python script built that will take that data and update these Feature Class Fields.
What I need to do is build a second python script that is composed of an if/else statement.
EXAMPLE:
   If ACALARA TYPE = 75 and ACALARA MODEL = 130
      Then the ACALARA METER TYPE field will update to show "CEN3S4S20"
   If ACALARA TYPE = 109 and ACALARA MODEL = 2
      Then the ACALARA METER TYPE field will update to show "UMT2.1"
There are around 2 dozen other combinations with additional Meter Type outputs that I will have to include
Figuring out how to write this code will help with other Feature Classes that I have been updating manually.
Thank You
ModernElectric
The I get: "RuntimeError: Unspecific error"
Says something about line 20
Does the code and everything look okay? I added your suggestion and nothing.
DanPatterson_Retired
start by fixing the first line an putting the 'fc' variable into raw format as Darren notes.  And on a side note, if you continue to use folders and filenames with spaces and other characters ... like dashes - ... you will continue to have problems.
'Says something about line 20'  .... write it down, screen grab it, but at least report it.  Error messages noted for a particular line are often the result of errors further on up the script, like the file name, because line 20 expects to use 'rows' but if the filename or fields are no good, the erro cascade begins.
curtvprice
Line 20 is where you call my function. This function seems to be working correctly though.
>>> proc(75, 130)
'CEN3S4S20'
>>> proc(109, 2)
'UMT2.1'
>> proc(109,4)
Runtime error
File "<string>", line 1, in <module>
File "<string>", line 10, in proc
Exception
Note, my code is assuming the actype and acmodel fields are numeric and your output field is string.
I will update the code to more gracefully handle unhandled combinations, there is a syntax error in my raise statement.
UPDATE: after my fix:
>>> proc(109,4)
Runtime error
File "<string>", line 12, in proc
Exception: Unhandled case: proc(109, 4)
