update.da.cursor question about fields
2121
6
11-23-2024 05:40 PM
CW-GIS
Hi everyone,
I'm stuck on a situation that I feel I'm making more complicated than it needs to be.
Situation:
I have a database (700K records) that updates daily, I convert it to a spatial dataframe. I have a hosted feature layer (points) that updates daily. Right now I truncate and append the entire thing, but having it empty for a while isn't ideal.
I want to basically this:
  • For each row in the database, search for the same 'key' in the hosted.
  • If return clause = 1
  • If any of the fields have different values, then update that field (or just the entire row)
  • else
  • If return clause = 0
  • insert cursor to insert that row
  • else next row
Where I am getting confused is, does the da.cursor just use field position to insert values? row[19] will update the 19th column. But what if someone inserts a new column in the database, would everything get screwed up? Can I instead just match the field names with a field map?
DanPatterson
MVP Esteemed Contributor
Fields are always added to the end.
If you want to get the field names prior to processing you can, and then produce an index to the name.
A simple example
fc0 = r'C:\\arcpro_npg\\Project_npg\\tests.gdb\\sq2'
from arcpy.da import SearchCursor
with SearchCursor(fc0, "*") as cursor:
    fld_names = cursor.fields
    n = len(fld_names)
    rpt = list(zip(range(0, n), fld_names))
    print(f"{rpt}")
    for row in cursor:
        print(f'{row[0]}')
[(0, 'OBJECTID'), (1, 'Shape'), (2, 'ids'), (3, 'CENTROID_X'),
 (4, 'CENTROID_Y'), (5, 'INSIDE_X'), (6, 'INSIDE_Y'),
 (7, 'PART_COUNT'), (8, 'PNT_COUNT'), (9, 'Sort_'),
 (10, 'Shape_Length'), (11, 'Shape_Area'), (12, 'Text')
, (13, 'Long_'), (14, 'Float_')]
6
9
There is limited information that you can get from the cursor
dir(cursor)
['__class__', '__delattr__', '__dir__', '__doc__', '__enter__', '__eq__',
 '__esri_toolinfo__', '__exit__', '__format__', '__ge__', '__getattribute__',
 '__getitem__', '__getstate__', '__gt__', '__hash__', '__init__',
 '__init_subclass__', '__iter__', '__le__', '__lt__', '__ne__', '__new__',
 '__next__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__',
 '__sizeof__', '__str__', '__subclasshook__',
 '_as_narray', '_dtype',
 'fields', 'next', 'reset']
# -- example
cursor._dtype
dtype([('OBJECTID', '<i4'), ('Shape', '<f8', (2,)), ('ids', '<i4'),
       ('CENTROID_X', '<f8'), ('CENTROID_Y', '<f8'), ('INSIDE_X', '<f8'),
       ('INSIDE_Y', '<f8'), ('PART_COUNT', '<f8'), ('PNT_COUNT', '<f8'),
       ('Sort_', '<i4'), ('Shape_Length', '<f8'), ('Shape_Area', '<f8'),
       ('Text', '<U20'), ('Long_', '<i4'), ('Float_', '<i4')])
the _as_narray can't be used if the fields includes the geometry, in such cases, you can use arcpy's FeatureClassToNumPyArray or TableToNumPyArray
... sort of retired...
JakeSkinner
Esri Esteemed Contributor
@CW-GIS you can use the Append tool and perform an upsert by specifying match fields.
TonyAlmeida
MVP Regular Contributor
Here is something I use daily to insert missing features.
import arcpy
# Paths to your database and hosted feature layer
database_path = "database"
hosted_layer_url = "feature_layer"
# Define the fields to be used
fields = ['unique_id', 'other_field', 'field1', 'field2', 'field3']  # Add all necessary fields here
# Count the number of features before the insert
initial_feature_count = int(arcpy.GetCount_management(hosted_layer).getOutput(0))
print(f"Initial number of features: {initial_feature_count}")
# Create a dictionary of database records for quick lookup
database_records = {}
with arcpy.da.SearchCursor(database_path, fields) as search_cursor:
    for row in search_cursor:
        unique_id = row[fields.index('unique_id')]
        database_records[unique_id] = row
update_count = 0
insert_count = 0
# Update or insert rows
with arcpy.da.UpdateCursor(hosted_layer, fields) as update_cursor:
    for row in update_cursor:
        if unique_id in database_records:
            matching_row = database_records[unique_id]
            # Check if any fields have different values
            updated = False
            for i, field in enumerate(fields):
                if row[i] != matching_row[i]:
                    row[i] = matching_row[i]
                    updated = True
            if updated:
                update_cursor.updateRow(row)
                update_count += 1
        else:
            # Insert new row if unique_id is not found
            with arcpy.da.InsertCursor(hosted_layer, fields) as insert_cursor:
                insert_cursor.insertRow(database_records[unique_id])
                insert_count += 1
# Count the number of features after the insert
final_feature_count = int(arcpy.GetCount_management(hosted_layer).getOutput(0))
print(f"Final number of features: {final_feature_count}")
print(f"Number of features updated: {update_count}")
print(f"Number of features inserted: {insert_count}")
print("Update and insert operations completed.")
CW-GIS
@TonyAlmeida   Thank you! This works.
I'm confused though, I run it once and I see it changes the values. If I run it a second time, 10 minutes later, shouldn't there be no edits because everything has already been edited to match the database?
When I run in 10 minutes later, it still makes the same number of changes as the first run.
TonyAlmeida
Your right, mine does the same. Try this.
Changes made are:
1- Trimmed whitespace and converted all field values to strings before comparison
2 - Prevents redundant inserts by comparing existing unique IDs in the hosted layer
import arcpy
# Paths to the local database and the hosted feature layer
hosted_layer = "feature_layer"
# Fields to check and update
fields = ['unique_id', 'other_field', 'field1', 'field2', 'field3']  # Update this list as needed
# Get the initial count of features in the hosted layer
# Create a dictionary to store records from the database for quick lookups
update_count = 0
insert_count = 0
# Process rows in the hosted layer to update existing records
            updated = False
            # Compare each field and update values if they differ
                if str(row[i]).strip() != str(matching_row[i]).strip():
                    updated = True
            if updated:
                update_count += 1
# Insert new rows for records in the database that are not in the hosted layer
with arcpy.da.SearchCursor(hosted_layer, ['unique_id']) as hosted_cursor:
    hosted_ids = {row[0] for row in hosted_cursor}
for unique_id, record in database_records.items():
    if unique_id not in hosted_ids:
            insert_cursor.insertRow(record)
            insert_count += 1
# Get the final count of features in the hosted layer
JoshuaBixby
Although Esri supports "*" for fields with ArcPy DA cursors, they did so reluctantly, and it is a bad practice.  You should always explicitly list the fields in a cursor, then you always know the order regardless of the order of the fields in the table.
