Update Cursor string error and attribute error
2685
09-18-2023 11:48 AM
RyShissler_Welland
I'm new to scripting and I'm trying to create a tool that takes street address from one field, makes it into a internal link, and then adds it to another field. I keep running into an error on line 69. I can't seem to find a solution.
File "<string>", line 69, in execute
AttributeError: __enter__
def addressParser(address):
    try:
       splitAddress = address.split(' ' , 1)
       firstLetter = splitAddress[1][0]
       streetName = splitAddress[1]
    except:
        arcpy.AddMessage('An error occurred while updating ' + address + '.')
    return firstLetter , streetName
import arcpy
class Toolbox(object):
    def __init__(self):
        """Define the toolbox (the name of the toolbox is the name of the
        .pyt file)."""
        self.label = "Toolbox"
        self.alias = "toolbox"
        # List of tool classes associated with this toolbox
        self.tools = [Tool]
class Tool(object):
    def __init__(self):
        """Define the tool (tool name is the name of the class)."""
        self.label = "Water Service Linker"
        self.description = ""
        self.canRunInBackground = False
    def getParameterInfo(self):
        param0 = arcpy.Parameter( # Allows user to select the table on which they'd like the action performed
            displayName = 'Table',
            name = 'param0',
            datatype = 'GPTableView',
            parameterType = 'Required',
            direction = 'Input')
        params = [param0]
        return params
    def isLicensed(self):
        """Set whether tool is licensed to execute."""
        return True
    def updateParameters(self, parameters):
        """Modify the values and properties of parameters before internal
        validation is performed.  This method is called whenever a parameter
        has been changed."""
        return
    def updateMessages(self, parameters):
        """Modify the messages created by internal validation for each tool
        parameter.  This method is called after internal validation."""
        return
    def execute(self, parameters, messages):
        """This tool will add folder link data to the WtrSrvcInstall Field"""
        table = parameters[0].valueAsText # converts the parameter to a useable string
        arcpy.AddMessage(table)
        fields = ['Civic_Name_Label' , 'WtrSrvcInstall'] #Defines the fields we'll be working in
        addressField = 'Civic_Name_Label' # The field title that contains the address info
        #linkField = 'WtrSrvcInstall' # The field title that will be the destination for the links
        folderBase = '\\\\polaris\\Infrastructure_ScanFiles\\WaterServiceSheets' # Sets the base link under which all other links exist
        arcpy.AddMessage(folderBase)
        #try:
        with arcpy.UpdateCursor(table , fields) as cursor: # sets the cursor in the correct table and fields
            for row in cursor: # iterates through each row
                first , street = addressParser(row[0])
                folderFull = folderBase + '\\' + first + '\\' + street
                arcpy.AddMessage(folderFull)
                row[1] = folderFull
        #except:
            #arcpy.AddMessage('An error occurred')
        return
    def postExecute(self, parameters):
        """This method takes place after outputs are processed and
        added to the display."""
        return
AlfredBaldenweck
MVP Frequent Contributor
Okay, so I'd still not use valueAsText here.
But.
Try using arcpy.da.UpdateCursor instead; it didn't throw any errors for me.
Oh wait that's probably the issue; arcpy.UpdateCursor and arcpy.da.UpdateCursor have different parameters.
AlfredBaldenweck
Try changing your table variable from parameters[0].valueAsText to parameters[0].value?
You're already asking for a table in the parameter, but you're feeding the cursor a string. Might be something else, but I'd at least give it a shot.
RyShissler_Welland
Hmmm I got the same error with .value unfortunately.
AlfredBaldenweck
But.
RyShissler_Welland
OMG yes, that worked! Thank you!
