Update Cursor script that allows selectable field to be updated?
1649
5
06-06-2013 12:23 PM
RachelAlbritton
I've written a code that selects attributes one by one. As each attribute is selected a select by location is performed to identify how many records in the select by location file intersect with the selected record from the select by attributes query. The number of records that intersect the selected attribute are recorded to the attribute table. The script works if the field to be updated is hardcodded into the script. I want to be able to pick what field gets to be updated each time the script is run. Is this possible?
import arcpy, os  arcpy.env.workspace = "C:/Temp" #arcpy.GetParameterAsText(0) arcpy.env.overwriteOutput = True outputWorkspace = "C:/Temp/Scratch" #arcpy.GetParameterAsText(1)  def outName(input,post="_Output"):     """Returns output name."""     outName=os.path.basename(input).split(".")[0]+post     return outName      Attribute = "Parcel_Test.shp" #arcpy.GetParameterAsText(2) Location = "Test_Wetlands.shp" #arcpy.GetParameterAsText(3)       #Get Count of the number of records for the file needing to be updated. #This count will be automatically plugged into a range value needed to write results from the analysis to the output shapefile. RangeCount = int(arcpy.GetCount_management(Attribute).getOutput(0)) print "There are", RangeCount, "records that need to be updated" arcpy.AddMessage("There are "+str(RangeCount)+" that need to be updated\n")  #Create Features Layers from Feature Classes AttributeFL=outName(Attribute,"_Layer") LocationFL=outName(Location,"_Layer") arcpy.MakeFeatureLayer_management(Attribute,AttributeFL) arcpy.MakeFeatureLayer_management(Location, LocationFL)  #Begin Update print "\nUpdating file with the number of records that intersect with each attribute" arcpy.AddMessage("Updating file with the number of records that intersect with each attribute\n")  for attribute in range(0,RangeCount):     FID = "FID=%s" % (attribute)     arcpy.SelectLayerByAttribute_management(AttributeFL,"NEW_SELECTION",FID)     arcpy.SelectLayerByLocation_management(LocationFL,"INTERSECT",AttributeFL)     LocationCount = int(arcpy.GetCount_management(LocationFL).getOutput(0))     arcpy.AddMessage(str(FID)+" has "+str(LocationCount)+" records that intersect with it.")     print str(FID), "has", LocationCount, "records that intersect with it."          #Update the three_mi field      uc=arcpy.UpdateCursor(AttributeFL)     for line in uc:         line.count = LocationCount         uc.updateRow(line) #Actually changes the table values to buffer count     del line     del uc      arcpy.SelectLayerByAttribute_management(AttributeFL,"CLEAR_SELECTION")      arcpy.AddMessage(Attribute+" has been updated\n") print Attribute, "has been updated\n"
ChrisSnyder
Honored Contributor
If your field name is a variable, you need to use the .setValue() method. For example:
myFieldName = "CRAZY_FIELD" line.setValue(myFieldName, LocationCount)
ChrisPedrezuela
You could just probably add a new input parameter:
inputFields = arcpy.GetParameterAsText(4)
Then from the script properties, in the parameters tab, set it to type "field", multiple input and indicate the source layer to get the fields from. You'll get a list of field names with checkboxes and any fieldname you check will be your input.
Cheers
import arcpy, os
    return outName
#Begin Update
    for line in uc:
    del line
    del uc
RachelAlbritton
Thanks for the reply. I have tried assigning a variable to a field, but I get a general 99999 error.
import arcpy, os
    return outName
Field = arcpy.GetParameterAsText(0)
#Begin Update
    for line in uc:
        line.Field = LocationCount
    del line
    del uc
Error Message:
  File "C:\Python26\ArcGIS10.0\Lib\site-packages\pythonwin\pywin\framework\scriptutils.py", line 326, in RunScript
    exec codeObject in __main__.__dict__
  File "C:\ArcGIS\Tools\Select_Update.py", line 67, in <module>
  File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\arcobjects\_base.py", line 35, in __setattr__
    return setattr(self._arc_object, attr, ao)
RuntimeError: ERROR 999999: Error executing function.
ChrisSnyder
Honored Contributor
RachelAlbritton
That worked - Thanks!
ChrisPedrezuela
Yup you need to use setValue since using line.Field makes the program think there is an actual fieldname "Field"
