Update attributes based on nearest feature class
863
07-05-2022 10:04 AM
JohnConnor01
Hello,
I am new to using Arcpy and need assistance. I have two feature classes: Poles and Lights. I need to update the Lights attribute, year installed, based on the nearest (within a 30 feet radius) Poles year installed value. What is the easiest way to go about this? I was thinking about generating a Near Table and then using Object IDs, or maybe using the Buffer tool?
Thank you for any help.
-JC from Boston
by Anonymous User
Not applicable
Using the near table would be most effective, as the Buffer could potentially find multiple features.
After you use generate the Near table, create a join between Poles and Lights using the ID for the nearest feature identified by the table. This will also allow you to filter out outliers and duplicates.
