Union all shapefiles in a geodatabase
2278
08-02-2012 11:04 AM
SuyunMa
I have 2806 polygon shapefiles stored in the same geodatabase and I want to union all of them together. So I was wondering how can I do that by using Python script. Thanks a lot.
SYM
JakeSkinner
Esri Esteemed Contributor
Hi SYM,
Here's an example:
import arcpy
from arcpy import env
env.workspace = r"C:\temp\python\test.gdb"
lstFCs = arcpy.ListFeatureClasses("*", "POLYGON")
arcpy.Union_analysis(lstFCs, "Union_FC")
This script is creating a list of all the polygon feature classes, and then passing this list as the input for the Union GP tool.
SuyunMa
Thanks a lot.
Hi SYM,
Here's an example:
import arcpy
ChristopherThompson
Does ArcView allow more than two inputs to a union?  I think that AV only accepts two inputs for intersects and think the same limitation applies to other overlay processes like union.
ChrisSnyder
Honored Contributor
ArcView only allows two FCs to be unioned at a time. Here is some ***untested*** Python code that could serve as a work-around:
#Be carefull to delete any "tmp_*" or "final_union" FCs before you run the code... otherwise those'll get unioned too
import arcpy
arcpy.env.workspace = r"C:\temp\python\test.gdb"
fcList = arcpy.ListFeatureClasses("*", "POLYGON")
i = 0
for fc in fcList:
   i = i + 1
   if i == 1:
      unionFcList = [fcList[i-1],fcList]
   else:
      inputTmpFC = "tmp_" + str(i-1)
      unionFcList = [fcList,inputTmpFC]
   outTmpFC = "tmp_" + str(i)
   arcpy.Union_analysis(unionFcList, outTmpFC)
   arcpy.Delete_managment(inputTmpFC)
arcpy.Rename_managment(outTmpFC, "final_union")
