UnicodeDecodeError: 'ascii' codec can't decode byte 0xe9 in position 6: ordinal not in range(128)
14129
12-02-2014 07:16 AM
TimothyHales
Esri Notable Contributor
I am trying to convert unicode to string, but I am getting UnicodeDecodeError. The original issue is related to working with a json return and creating a string, but here is a simplified example:
raw = unicode("Soporté")
print string
I have tried the suggestion from here: Rename layer with unsupported signs in a mxd via python?
string = raw.decode('utf-8')
print string
And here: Write Russian field names to txt
string = raw.encode('utf-8')
print string
But I get the same error: UnicodeDecodeError: 'ascii' codec can't decode byte 0xe9 in position 6: ordinal not in range(128)
BruceHarold
Esri Frequent Contributor
raw = u'Soporté'
>>> print raw
Soporté
BruceHarold
raw = u'Soporté'
>>> print raw
Soporté
TimothyHales
Thanks Bruce Harold‌! That works for printing the text, but I've added some complexity beyond printing. I am trying to concatenate the unicode with a string and append it to a list.
list = []
raw = u'Soporté'
list.append("Department: {}".format(raw))
print list
TimothyHales
Add the 'u' in front of my concatenated string as Bruce Harold‌ suggested worked. Thanks!
list = []
raw = u'Soporté'
list.append(u"Department: {}".format(raw))
print list
