Unicode error
10611
11
07-29-2015 02:22 PM
AmyKlug
When i am running this code i am getting a Unicode error half way through. Not sure what mxd/layer file name is hanging it up (line 33) on but not sure where to put the fix (line 7 - or if this is the correct fix) either.
import arcpy, os
#code adds mxd name and layer path name to text file separated by a comma
arcpy.env.overwriteOutput = True
#def Utf8EncodeArray(oldArray):
    #newArray = []
    #for element in oldArray:
        #if isinstance(element, unicode):
        #newArray.append(element.encode("utf-8"))
    #else:
        #newArray.append(element)
    #return newArray
path = "////serverpath"
#path2 =
mxdlst = []
txt = open("text file path", 'w')
print "making mxd list"
for root, dirs, files in os.walk(path):
    for fname in files:
        if fname.endswith(".mxd"):
            mxd = root + '\\' + fname
            mxdlst.append(mxd)
del mxd, fname
for mapdoc in mxdlst:
    mxd = arcpy.mapping.MapDocument(mapdoc)
    for df in arcpy.mapping.ListDataFrames(mxd, "*"):
        for lyrlst in arcpy.mapping.ListLayers(mxd, "*", df):
            if lyrlst.supports("DATASOURCE"):
                txt.write(mapdoc + "," + lyrlst.workspacePath + "\\" + lyrlst.name + "\n")
                print "adding" + mapdoc + "," + lyrlst.workspacePath + "\\" + lyrlst.name + "\n"
            else:
                txt.write(mapdoc + "," + lyrlst.name + "\n")
                print "adding" + mapdoc + "," + lyrlst.name + "\n"
txt.close()
del mxd, df, lyrlst, mapdoc, mxdlst
Tags (3)
DanPatterson_Retired
What is the layer name etc?  If it contains  characters that need to be converted, then you will have to do so
AmyKlug
I need code to check for that and fix it just not sure where to put it
haven't had the unicode issues yet, but apparently, I will have to and one suggestion is to specify encoding at the top of the script with
# -*- coding: utf-8 -*-
​but some unicode types should step up since it appears that you have a character that can't be represented by the ASCII chars in the range 0-127
AmyKlug
I have seen that before. does it work with the # sign in front?
apparently that is what is supposed be done, first line.  but I seriously haven't played with encoding other than ascii ... I really should given accented characters etc, but so far, haven't had to deal with.  My only suggestion is find someone that works with such data and or look at at one of the files and see what characters are present there.  Sorry I can't help more, but searching on your error message on GeoNet may turn up more
XanderBakker
Esri Esteemed Contributor
An interesting article to read would be:
Solving Unicode Problems in Python 2.7 | Azavea Labs
And to give an example of what works and fails:
myText = u"example of únì¢ødë"
# this works:
print myText
# UnicodeEncodeError: 'ascii' codec can't encode character u'\xfa' in position 11: ordinal not in range(128)
print "{0}".format(myText)
# inserting unicode in a str
# This works
print u"{0}".format(myText)
# inserting unicode into a unicode
print u"{0}".format(myText.decode('utf-8'))
# inserting utf-8 into unicode
what a kludge...
  1. chars = [unichr(i) for i in range(0,256) if (32 < i < 128) or (i > 161)]
print "Unicode characters 33-127 and 161-255\n" + ("{:5}"*len(chars)).format(*chars)
!    "    #    $    %    &    '    (    )    *    +    ,    -    .    /    0    1    2    3    4    5    6    7    8    9    :    ;    <    =    >    ?    @    A    B    C    D    E    F    G    H    I    J    K    L    M    N    O    P    Q    R    S    T    U    V    W    X    Y    Z    [    \    ]    ^    _    `    a    b    c    d    e    f    g    h    i    j    k    l    m    n    o    p    q    r    s    t    u    v    w    x    y    z    {    |    }    ~        ¢    £    ¤    ¥    ¦    §    ¨    ©    ª    «    ¬    ­    ®    ¯    °    ±    ²    ³    ´    µ    ¶    ·    ¸    ¹    º    »    ¼    ½    ¾    ¿    À    Á        à   Ä    Å    Æ    Ç    È    É    Ê    Ë    Ì    Í    Π   Ï    Р   Ñ    Ò    Ó    Ô    Õ    Ö    ×    Ø    Ù    Ú    Û    Ü    Ý    Þ    ß    à    á    â    ã    ä    å    æ    ç    è    é    ê    ë    ì    í    î    ï    ð    ñ    ò    ó    ô    õ    ö    ÷    ø    ù    ú    û    ü    ý    þ    ÿ
anything not visible, isn't...can't wait to learn all of them
Luke_Pinner
MVP Regular Contributor
Dan Patterson:
...one suggestion is to specify encoding at the top of the script with # -*- coding: utf-8 -*-
This only applies to literal characters in the python script file itself, not any string variables when the script is run.
test_noenc.py
somestr = u'über còól'
print somestr
test_enc.py
print somestr
C:\Temp>python test_noenc.py
  File "test_noenc.py", line 1
SyntaxError: Non-ASCII character '\xfc' in file test_noenc.py on line 1, but no encoding declared; see http://python.org/dev/peps/pep-0263/ for details
C:\Temp>python test_enc.py
über còól
Thanks Luke...fixed
