UnboundLocalError using sequence
1521
01-27-2021 12:59 PM
StevenCross
Hello all,
I have a script where I am parsing through all the MXD's on the server and getting the service properties of all the feature classes and writing to a csv file.
I am running into an issue in an else statement where it is UnboundLocalError: local variable 'db' referenced before assignment.
I have tried changing the indentation of the sequence and when I put that inside the else statement I only get the first MXD in the folder written to the csv.
Below is the script. Any help would be appreciated.
import arcpy, os, csv, socket
#Turn off ESRI geoprocessing logging so XML column does not fill up
arcpy.SetLogHistory(False)
arcpy.gp.overwriteOutput = True
ags = socket.gethostname()
print "ArcGISServer:" +     ags
def main(folder, outputfile):
    with open(outputfile, "wb") as f:
        w = csv.writer(f)
        header = ("MapDocument", "LayerName", "FeatureClass", "Database", "Server", "Version", "UserName", "Authentication", "ArcGISServer")
        w.writerow(header)
        rows = crawlmxds(folder)
        w.writerows(rows)
def crawlmxds(folder):
    for root, dirs, files in os.walk(folder):
        for f in files:
            if f.lower().endswith(".mxd"):
                mxdName = os.path.splitext(f)[0]
                mxdPath = os.path.join(root, f)
                mxd = arcpy.mapping.MapDocument(mxdPath)
                print mxdPath
                print mxdName
                for lyr in arcpy.mapping.ListLayers(mxd):
                    if lyr.supports("DATASOURCE"):
                        dSource = str(lyr.dataSource)
                        if '.sde' in dSource:
                            fcName = dSource.split('.sde\\')
                            print "Layer Name: " + lyr.name
                            print "Feature Class: " + fcName[1]
                        elif '.gdb' in dSource:
                            fcName = dSource.split('.gdb\\')
##                        if lyr.supports("definitionQuery"):
##                            dq = lyr.definitionQuery
##                            print "Definition Query: " + lyr.definitionQuery
##                        else:
##                            print "NA"
                        if lyr.supports("SERVICEPROPERTIES"):
                            if lyr.serviceProperties["ServiceType"] != "SDE":
                                print "Service Type:  " + lyr.serviceProperties.get('ServiceType', 'N/A')
                                print "     URL:          " + lyr.serviceProperties.get('URL', 'N/A')
                                print "     Connection:   " + lyr.serviceProperties.get('Connection','N/A')
                                print "     Server:       " + lyr.serviceProperties.get('Server','N/A')
                                print "     Cache:        " + lyr.serviceProperties.get('Cache','N/A')
                                print "     User Name:    " + lyr.serviceProperties.get('UserName','N/A')
                                print "     Password:     " + lyr.serviceProperties.get('Password','N/A')
                                print ""
                            else:
                                print "Service Type:  " + lyr.serviceProperties.get('Service Type', 'N/A')
                                db = lyr.serviceProperties.get('Database', 'N/A')
                                print "     Database:       " + lyr.serviceProperties.get('Database', 'N/A')
                                svr = lyr.serviceProperties.get('Server', 'N/A')
                                print "     Server:         " + lyr.serviceProperties.get('Server', 'N/A')
                                srvc = lyr.serviceProperties.get('Service', 'N/A')
                                print "     Service:        " + lyr.serviceProperties.get('Service', 'N/A')
                                ver = lyr.serviceProperties.get('Version', 'N/A')
                                print "     Version:        " + lyr.serviceProperties.get('Version', 'N/A')
                                un = lyr.serviceProperties.get('UserName', 'N/A')
                                print "     User Name:      " + lyr.serviceProperties.get('UserName', 'N/A')
                                auth = lyr.serviceProperties.get('Authentication', 'N/A')
                                print "     Authentication: " + lyr.serviceProperties.get('Authentication', 'N/A')
                                print ""
                        seq = (mxdName, lyr.name, fcName[1], db, svr, ver, un, auth, ags);
                        yield seq
                del mxd
if __name__ == "__main__":
    folderPath = r"mxdpath" # or arcpy.GetParameterAsText(0)
    output = r"csvpath" # or arcpy.GetParameterAsText(1)
    main(folderPath, output)
DavidPike
MVP Notable Contributor
Just glanced through, but you've not created the variables (db, svr...) to yield when the condition is met (not SDE) - only when SDE.  A quick fix might be to assign them within that if true block - db = "None" ... etc.
Far from a coding whizz so take a big pinch of salt with that.
DanPatterson
MVP Esteemed Contributor
the variable/property "db" only gets a value in one case.
A safe way of finding out what is going on is to assign potential returns to some value, whether it be None prior to running any loops.  For example
db = None; svr =None;  ver = None; un = None; auth = None;  ags = None
def crawlmxds(seq):
    for i in seq:
        print("{}".format(i))
seq = [db, svr, ver, un, auth, ags]
crawlmxds(seq)
None
None
None
None
None
None
Then when you see a None, you know something is wrong.
The alternative is check each variable assignment before you try to use it, as is your current case.
... sort of retired...
StevenCross
Thanks Dan and David! I took a look at both of your suggestions and what think I may have found a solution...however not the prettiest or most understandable but if I put the variables after the Service Type variable like below it works.
                                print ""
                            else:
                                print ""
                        yield seq
